meister808
747SUD And Other Emergency AD
Sat Feb 19, 2005 4:31 am
Turns out that the upper deck on some classics has been having trouble. Not really a deal, but thought y'all might find it interesting, especially considering the fact that the AD was issued yesterday:
http://www.airweb.faa.gov/Regulatory...1963D86256FAC00533907?OpenDocument
And to quell the inevitable, no, this does not mean that the 747 is unsafe and/or should be grounded. ADs happen to every aircraft that has ever been built.
It is interesting, however, that they want this inspected once every 25 cycles. Thats pretty often.
-Meister
dl757md
RE: 747SUD And Other Emergency AD
Sat Feb 19, 2005 5:54 am
Quoting Meister808 (reply 0):
Not really. 25 cycles on a 747 can be more than 200 hrs. Not a lot when you consider 100 hr inspection on GA aircraft. Also the repetitive inspections (25 cycle) are no longer needed after an HFEC(High Frequency Eddy Current) inspection. The reason for the high frequency of the visual inspetions is that your are looking for EXTERNAL signs of already existing INTERNAL damage. This damage may take hundreds or thousands of hours to show up externally. The HFEC is a non-destructive test that show all internal damage and a successful HFEC inspection insures that there is no damage at all, external or internal.
Dl757Md
meister808
Sat Feb 19, 2005 6:18 am
Fair enough. I am assuming most of the operators of these aircraft are going to opt to just go ahead and do the HFEC inspection, then? Is that an expensive one?
-Meister
B747FE
Sat Feb 19, 2005 6:26 am
Interesting info.
I think most of the operators will go directly for the HFEC in order to avoid the repetitive inspections.
In our fleet we made the mod specified as a terminating action.
Quoting Dl757Md (reply 1):
Yes, in a -200/300 series.
The SUD mod was also available for -100B SR.
25 cycles for us means 50 to 60 flight hours, in one week.
B747FE.
"Flying is more than a sport and more than a job; flying is pure passion and desire, which fill a lifetime"
dl757md
Sat Feb 19, 2005 7:14 am
Quoting Meister808 (reply 2):
If the operator has their own equipment and personnel it shouldn't be too bad. If they have to contract it out then it could get expensive. I have no idea how long it would take as I'm not sure of the size of the area or the exact requirements for the inspection.
Dl757Md
Users browsing this forum: No registered users and 29 guests
