dogfighter2111
B762ER Fuel Usage?
Thu Nov 24, 2005 4:05 am
Hey,
This is an odd question but here it is:
What is the fuel used by ONE engine of a B762ER; in pounds?
Mike
charliecossie
RE: B762ER Fuel Usage?
Thu Nov 24, 2005 6:05 am
Appoximately the same as the other one.
 Smile
kaddyuk
Thu Nov 24, 2005 8:26 am
Quoting Dogfighter2111 (Thread starter):
Hey,
in pounds?
I dont know what the value is, however Fuel Flow is measured in unit weight per hour.
I'd expect it to be around the 2000lbs/hr range.
Thu Nov 24, 2005 11:57 am
Quoting Kaddyuk (Reply 2):
Which Engine Type are you reffering to.
regds
MEL
AJ
Thu Nov 24, 2005 12:00 pm
Depends on the type of engine fitted, the thrust setting required and the environmental conditions.
At 35,000 feet at ISA +10 in a 130,000kg 767-200ER each JT9D would burn approximately 4824lbs/hr at 461ktas cruise.
kaddyuk
Thu Nov 24, 2005 12:56 pm
Quoting AJ (Reply 4):
Wow, i wouldn't have expected it to be that high...
dogfighter2111
Thu Nov 24, 2005 4:26 pm
Hey guys, it is for a B767-200ER. Engines are CF6's.
Mike
Molykote
Tue Nov 29, 2005 5:35 pm
I am showing from 4500 lb/hr to 5100 lb/hr (per engine) on our fleet depending on factors mentioned above - routing (and associated weight) in particular.
Speedtape - The aspirin of aviation!
dogfighter2111
Tue Nov 29, 2005 6:55 pm
Thanks m8. Just info i was looking for.
Mike
airxliban
Wed Nov 30, 2005 9:36 am
Were the JT9Ds not available on the 200ERs?
rendezvous
Wed Nov 30, 2005 6:48 pm
Qantas flew 762/ERs with JT9D's on them.
Users browsing this forum: Majestic-12 [Bot], TZTriStar500 and 28 guests
