JulianUK
Autoland In Crosswinds Situations Question
Thu May 04, 2006 10:18 pm
How good is modern autoland in crosswinds? Will it do wing down into the wind itself or does it need some assistance from the person up front? Is there any constraint on crosswind landings with autoland in use? for example if it is a gusty crosswind with sudden changes in wind speed can it react well? just interested in different aircraft types and their characeteristics.
J
CosmicCruiser
RE: Autoland In Crosswinds Situations Question
Thu May 04, 2006 11:25 pm
MD-11 autoland x-wind limits...15kts; for CATII/III...10kts.
It does a very good job on it's own.
longhauler
Fri May 05, 2006 1:17 am
A320/A321/A319 crosswind limits are 15Kts for all autolands including CatII and CATIII Dual, (no DH).
It does a crosswind landing just like you or me. One wing down, maintain lateral orientation with rudder.
Very recently we are now authorized to do single engine CatIII, with up to a 15kt crosswind. The only restriction is on the amount of reverse thrust you use ... it varies with the crosswind.
411A
Tue May 16, 2006 11:33 am
L1011.
Crosswind restriction during automatic approach/landings (autolands) is 35 knots, on dry runways.
25 knots if wet.
15 knots if CATIII.
2H4
Tue May 16, 2006 11:37 am
Quoting 411A (Reply 3):
Wow.
2H4
Intentionally Left Blank
highflyer9790
Tue May 16, 2006 11:42 am
Quoting LongHauler (Reply 2):
doesnt auto throttle automatically deploy the reversers? how much, if anything, is done by the pilots in an autoland besides monitoring, assuming they do not disconnect the auto pilot at DH in a CAT I or II?
121
EssentialPowr
Tue May 16, 2006 12:39 pm
On the 737s (NGs and classics), A/Ts disconnect 2 sec after touchdown, so reverse thrust is manual.
CX Flyboy
Tue May 16, 2006 3:26 pm
In the 777-200 and 777-300, autoland crosswind limits are the same as manual landings, so 38kts crosswind on a dry runway, 20kts for slush/water/snow, and 15kts for ice and compact snow.
The exception is a 25kt autoland crosswind limit for LWMO landings.
Autoland is great for single engined landings too.
wing
Tue May 16, 2006 7:25 pm
Quoting HighFlyer9790 (Reply 5):
Normally all landing calculations are done without the reverse thrust.And usage of reverse thrust varies between the airport requirements(noise issues),crosswing requirements and operational requirements of the airplane and the runway.
Reverse thrust is not operated by the autoland system nor its a part of it.Pilots choose the amount of the reverse thrust and depending on the conditions.
Just to clearify something here.You can make an autoland on a CAT I day,so you don't have to disengage the AP on the DH.But on the other hand you may compleate the landing on a CAT II approach with a manual landing after the DH(if you have the visual ques)
follow me on my facebook page" captain wing's journey log"
Users browsing this forum: David L and 17 guests
