airplanecrazy
Fuel Consumption As Aircraft Ages
Thu May 11, 2006 9:01 am
Does the fuel consumption (and thereby range) of an aircraft change as the aircraft ages? Cars will get better gas mileage after they are broken in, so I was wondering if a similar effect happens with airplanes. Perhaps the range actually decreases as the aircraft skin gets dirty or dinged?
fr8mech
RE: Fuel Consumption As Aircraft Ages
Thu May 11, 2006 9:45 am
Quoting AirplaneCrazy (Thread starter):
Don't you just love it when you answer your own question? Also, as the engine ages, it gets less efficient because the clearances open up.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
LAXintl
Thu May 11, 2006 10:10 am
Aircraft performance in general declines after a few years of ownership due to both airframe engine degradation.
Everything from engine EGT margin loss, flight control surface rigging issues, aircraft weight gain etc.. all serve to reduce performance.
airplanecrazy
Thu May 11, 2006 10:36 am
Quoting Fr8Mech (Reply 1):
Do you know how signficant the change can be? Are we talking 1-2%, or more?
liedetectors
Thu May 11, 2006 11:24 am
Quoting AirplaneCrazy (Reply 3):
Depends no how whipped you let your engine become.
A big killer is fan blade deterioration. As the fan tip wear down, they create gaps. These gaps cause a drop in EPR and a result, N2 must increase to maintian EPR. This, of course, would drive up fuel flow as the engine is now running faster and hotter.
If it was said by us, then it must be true.
LAXintl
Thu May 11, 2006 11:35 am
Performance deterioration tends to stabilise in mid age aircraft. Its not uncommon for middle age Airbus and Boeing types to be 5% or more percent from aircraft book performance values.
Many airlines have proactive engine and airframe maintenance programs to win back some of the degradation particularly these days with the high cost of fuel.
airplanecrazy
Thu May 11, 2006 11:40 am
Quoting Liedetectors (Reply 4):
I know the latest GE engine blades are made of a carbon-reinforced epoxy with titanium leading edges. Is there any noticeable difference in the blade wear between these blades and more traditional blades?
2H4
Thu May 11, 2006 12:41 pm
I've always wondered how much weight could be removed from a 40-year-old airliners if you could somehow turn it upside-down and shake out the years and years of dirt, pens, grime, trash, and assorted debris that have collected in all the nooks and crannies...
2H4
Intentionally Left Blank
kdeg00
Thu May 11, 2006 12:47 pm
I was thinking along similar lines last week, looking at the various patches on the engine cowling of my 752. My question was how much additional drag an older airframe had because of the repairs to normal bumps and bruises.
AS 75K, DL Gold, BA Silver
Molykote
Thu May 11, 2006 3:38 pm
Yes.
Aircraft performance deteriorates for a number of reasons with age.
- "Dust Bunnies" and other junk accumulated in nooks and crannies of the airframe.
- Repairs will add weight and be somewhat detrimental to aerodynamics if external.
- Engine deterioration
- Slop in the rigging of flight controls, gear doors, etc.
I'm sure others will have more to add. A deterioration of 2-3% is in the ballpark of "normal" after a few to several years.
Speedtape - The aspirin of aviation!
pavlin
Thu May 11, 2006 6:12 pm
I am not sure about that. You should take a look at those valves after 100.000km
AvionicMech
Thu May 11, 2006 7:36 pm
Every airline should produce either fuel flow factor and drag factor charts or maybe just a fuel flow factor chart for each aircraft to be entered into the FMC. When a navigational database is loaded to the FMC on older systems it will wipe out the FF and drag factors and they will need to be re entered once the update is complete. At my airline we only enter a FF factor and leave the drag factor at 0.0. This FF figure is updated every 3 months I believe, using actual fuel used for a flight and comparing it to the expected fuel burn.
Most of our aircraft have a figure of around 2-3 but some with a couple of old engines may be as high as 5, but that is unusual.
F14D4ever
Thu May 11, 2006 8:03 pm
A bigger killer is turbine blade deterioration. After initial rubs, fan blades aren't as prone to continued tip wear as turbine blades, because in addition to mechanical growth/shrinkage, turbine blades suffer airfoil degradation due to thermal stress, which obviously happens continuously through their life cycle.
"He is risen, as He said."
Users browsing this forum: No registered users and 109 guests
