CoolGuy
Shortest Runway Needed For A 737...
Thu Feb 22, 2007 1:51 pm
Sometimes I see the numbers on the side of the runway decreasing quite rapidly before a 737 I'm on lands: 9, 8, 7... When would a pilot need to abort a landing? (Suppose clear weather.) Sometimes it feels like the plane is just hovering a few feet above the runway (maybe due to the ground effect) and I always wonder if it's going to go back up. (That happened to me once but only because the plane never got clearance to land!)
chrisMUC
RE: Shortest Runway Needed For A 737...
Thu Feb 22, 2007 11:50 pm
I can give you figures for the required landing distances of a B737-300:
60t (above our max. of 57.6)
dry runway: 1710m (flaps 40), 1790m (flaps 30)
wet runway: 1970m, 2050m
dry autoland: 2020m, 2100m
wet autoland: 2280m, 2360m
34t
dry runway: 990m (flaps 40), 1030 (flaps 30)
wet runway: 1140m, 1180m
dry autoland: 1300m, 1340m
wet autoland: 1450m, 1490m
Conditions: Sea Level, ISA, Zero Wind, Anti-skid operative, Automatic Speed Brakes
Definition of required landing distance:
The Required Landing Distance is the demonstrated landing distance divided by 0.6; demonstrated landing distance is based on a speed of 1.3xVs in landing config at the 50ft point; dry smooth level, hard surfaced runway; brakes fully applied, no thrust reverse.
Required landing distance wet is 1.15 times the dry one.
For emergencies actual landing distances are used (but you have to keep in mind that you won't reach the Boenig test pilots' values), for example:
One Engine Inoperative, Flaps 15 Landing, Standard Conditions, 46t: 820m
(1m = 3.281ft; 1t = 2204.6lb)
If you like the get more information - let me know. I have stand-by and am quite bored  Wink
CoolGuy
Fri Feb 23, 2007 2:41 am
I'm really wondering when a landing would be aborted if it doesn't touch down in time. Sometimes I see the airplane sort of hovering slightly above ground for a long time (well, longer than I would expect by looking out the window).
flyf15
Fri Feb 23, 2007 2:58 am
Quoting CoolGuy (Reply 2):
Landing requirements are based on the aircraft crossing the threshold of the runway at a certain altitude and airspeed and touching down within the touchdown zone. This usually means crossing the threshold at Vref with a decelerating trend, at 50ft agl, and touching down in the first 3000ft of the runway.
mighluss
Fri Feb 23, 2007 4:59 pm
A photo that appeared today...
Photo © Ricardo Coppola
I think Santos Dumont is the shortest rwy, that receives 737's in a normal basis. It has just 4341 ft !!
Miquel.
flynavy
Sat Feb 24, 2007 10:01 pm
I've seen private 737-200s operating in and out of Key West (KEYW) a few times. EYW's runway is 1463 by 30 meters. Dumont definitely has EYW beat, though. Just my two cents.
Change is: one airline, six continents!
Viscount724
Sun Feb 25, 2007 8:27 am
Quoting Mighluss (Reply 4):
Boeing has developed special short-runway modifications for the 737NG, mainly to facilitate Gol's operations of the 737-800 to/from SDU with its very short runways ending in water at both ends. Related Boeing press release:
http://www.boeing.com/news/releases/2006/q3/060729a_nr.html
Users browsing this forum: thepinkmachine and 44 guests
