Quoting Dw747400 (Reply 3): Plus, regular fuel dumping tends to irritate the environmentalist! |
Quoting Fr8Mech (Reply 2): If the vapor trail you saw was coming from the tail, it was probably the contrail from the APU exhaust. |
Quoting KELPkid (Reply 5): As I understand it, doesn't most of the fuel "harmlessly" vaporize before reaching the ground? |
Quoting OPNLguy (Reply 1): What you probably saw was moisture. |
Quoting FLY2HMO (Reply 7): A contrail? A couple thousand feet of the ground? |
Quoting Max Q (Reply 10): More likely you saw moisture from a rear drain mast freeze instantly into a mini 'contrail' |
Quoting SSTsomeday (Reply 12): Where would the moisture come from at the end of the flight? |
![]() Photo © Paul Markman | ![]() Photo © Stuart Haigh - topjetpix |
Quoting Airfoilsguy (Reply 11): Correct me if I am wrong but don't most airliners that have the ability to dumb fuel do so by nozzles mounted on the wings and not the tail. It would only make sense to mount fuel dump nozzles closest to the main tanks. |
Quoting Futurecaptain (Reply 16): Basically, the ability to dump fuel isn't really needed except for the biggest planes. |
Quoting Futurecaptain (Reply 16): No, most airliners do not have the ability to dump fuel. |
Quoting Max Q (Reply 10): In any case the 757 cannot jettison or dump fuel, the 767 can |
Quoting OPNLguy (Reply 14): Quoting SSTsomeday (Reply 12):Where would the moisture come from at the end of the flight? In the atmosphere itself... You won't see such a thing occur someplace like PHX very often (dry air), but given that LAX is next to that big ocean thingie out to the west, LAX sees moisture-laden air all the time... |
Quoting SSTsomeday (Reply 19): Most likely smoke from the APU unit being started up (therefore the smoke) because they do not create smoke while running on the ground |
Quoting Futurecaptain (Reply 16): No, most airliners do not have the ability to dump fuel. But in an emergency all aircraft can land at max weight without dumping anything, although the plane will require a check afterward. Basically, the ability to dump fuel isn't really needed except for the biggest planes. |
Quoting Airfoilsguy (Reply 22): Try again, this time read slower. |
Quoting Valkyrie01 (Reply 24): How about when starting the APU when it is really cold you see a few puff and more |
