LTU932
Question On Nose Intakes On Douglas DC-8
Wed Mar 28, 2007 12:30 pm
I searched for a thread on this, but couldn't find it. My question is about these intakes, that are right by the nose of Douglas DC-8s.
Photo © Lars Söderström
What's the purpose of these intakes? I haven't seen such intakes on other contemporary aircraft such as the 727 or 707, just on the DC-8.
N231YE
RE: Question On Nose Intakes On Douglas DC-8
Wed Mar 28, 2007 1:02 pm
Those are for the turbocompressors, used to pressurize the cabin. The Boeing 707/720 had them in the engine nacelles, just above the engine's air intake.
113312
Thu Mar 29, 2007 4:04 am
Each of those chin scoops have three holes. There is a large opening in the middle which takes in air for the air-to-air heat exchanger on that side. There are also two smaller holes that are the individual inlets for the turbocompressors. On the DC-8, there are a total of 4 turbocompressors. The Boeing 720 series had two turbocompressors and most 707 series aircraft had three.
It should be pointed out that the DC8/Boeing 707/720 generation of aircraft didn't bleed air directly from the engines for pressurization and air conditioning. Rather, a small amount of engine bleed air was used to spin turbo-compressors which drew in fresh air, compressed it and raised it's temperature. This air, cooled via heat exchangers and freon units, was directed to the cabin distribution system.
The Boeing 727, 737, and DC-9 generation of planes using JT8 series engines were the first to use bleed air from the engine itself, through air conditioning "packs" to directly pressurise the cabin and for temperature control.
In later years, when the JT3 engines, on DC8s, were replaced with CFM-56 powerplants, the turbocompressors and freon cooling units were removed and replaced with "packs" that allowed engine bleed air to be used for temperature control and cabin pressurization. The DC8 chin scoops were modified to close off the turbocompressor inlets.
LTU932
Thu Mar 29, 2007 11:01 am
Quoting N231YE (Reply 1):
You mean here:
Photo © Carlos Borda
While I know all engines have these "extensions" on all engines except the number 1, it's curious to see that in this freighter, it's not on the number 4 as well.
Photo © Normando Carvalho Jr.
I guess that since this aircraft isn't used for PAX flights anymore, it was removed from the number 4.
Quoting 113312 (Reply 3):
Thanks for the detailed explanation!
N231YE
Thu Mar 29, 2007 1:19 pm
Quoting LTU932 (Reply 4):
You mean here:
I should have said the TCs were in the engine pylons, with the opening just above the engine air intake.
Grunf
Thu Mar 29, 2007 8:44 pm
Early jet engines had a bad habbit of leaking some oil troughout compressor stages so an turbocharger was used to isolate PAX from bleed air which was considered "dirty". New engines didn't have the problems anymore and turbochargers were removed...
CaptOveur
Fri Mar 30, 2007 3:15 pm
Nope.. 707s only had 3 turbocompressors, no matter what they are being used for.
411A
Sat Mar 31, 2007 1:43 am
Well, in actual fact, some B707 freighter aircraft did indeed have the number four engine turbo-compressor removed.
Two T/C's are sufficient on B707 freighter aircraft to keep the cabin properly ventilated, as well as, of course, pressurized.
Now, someone might ask....'what happens IF one of the turbocompressors fails in flight?'
This is generally not a problem, as most B707's that did NOT have vapor (freon) cycle air conditioning, also had engine bleeds, that cound be used to pressurize the cabin.
The only proviso with using engine bleeds in lieu of T/C's was that descents needed to be started sooner, using partial thrust as opposed to idle thrust, as the engine bleed air did not have the volume capacity as a turbo-compressor delivered.
Making bold statements about the B707 without ever having actually flown one sometimes paints one into a corner, as some of the information provided about this rather remarkable airplane on some internet sites is, at best, somewhat misleading.
As for me personally, I have flown, in Command, many models of the B707, both freighter and passenger versions, straightpipe and turbofans, for over ten years in the past, prior to moving to the L1011.
Next question?
N231YE
Sat Mar 31, 2007 2:35 am
Quoting 411A (Reply 8):
Next question?
Can I have your job?  silly
Sat Mar 31, 2007 3:02 am
Quoting CaptOveur (Reply 7):
As 411A says, aircraft come in many variations. This is especially true when they start to age.
My guess is that the 707s always had 3 turbocompressors when they left the factory. But as stated above, this was removed in some cases. After market mod just like a trunk wing on a Honda.
411A
Sat Mar 31, 2007 3:27 am
Of course, N231YE, you can have my job...so long a I get paid.
We are, however, starting to run out of L1011 First Officers, as there are not many L1011's left in service, and the younger First Officers want to move onto an airplane that has, shall we say, a longer future.
Within the next few months, those in southern Europe will see, once again. scheduled service with the L1011...look for it in Lisbon....if all goes according to plan.
The AOC is issued, the airplane will be in maintenance shortly, and the funding is in place.
Ticket sales, on a limed basis, will be next.
One step at a time.
2H4
Sat Mar 31, 2007 5:12 am
Quoting 411A (Reply 11):
Fools.  yes
2H4
113312
Sat Mar 31, 2007 6:24 am
American Airlines ordered most of their B707 aircraft with only two turbocompressors. Most of the 707-320 freighters you see today that have turbocompressor inlets only on the inboard engines will likely turn out to be -323B/C models originally from American Airlines. It isn't that the third T/C was removed, it was never installed in the first place.
I would like to note that American was an early customer of the turbojet 707-123 before the days of the JT3D "fan" engine. On these organ pipe turbojets, there is a hole above all four of the main engine inlets. On the AA aircraft, the outboard engines didn't have T/Cs so this was a dummy hole. When these ships were converted to the turbofan engines, the pylon was modified so that the inboard ones had the holes for the T/C and the outboard ones didn't just like the B720B models.
LTU932
Sat Mar 31, 2007 9:28 am
Quoting 113312 (Reply 13):
Indeed. I didn't even notice until now that this picture I linked was from a former AA bird.
N231YE
Sat Mar 31, 2007 10:14 am
Quoting 2H4 (Reply 12):
Fools.
Glass cockpits make nice eye candy...but real pilots fly steam
Well, um...you see, being a [broke] college student, um, I have holes in my pockets.
[Edited 2007-03-31 03:27:34]
ReidYYZ
Sat Mar 31, 2007 10:22 am
Quoting Starlionblue (Reply 10):
Yeah, but the modified seven-oh didnt make the pilot look like a mouth-breather flying it.
slz396
Sun Apr 01, 2007 4:05 am
I thought bleedless engines were something new, but it seems the 787 is simply going back to a design from the past?
redflyer
Fri Apr 06, 2007 7:41 am
Quoting Slz396 (Reply 17):
If you really think about it, they are using a form of "glue" -- the resin in the CFRP -- to build the 787. So I guess that is quite the throw back to the early age of aviation when glue was used to hold together components of an airplane.  Wink
Jetlagged
Fri Apr 06, 2007 8:32 am
Quoting RedFlyer (Reply 18):
Glue never went away. De Havilland (then Hawker Siddeley, then BAe) used glue (called redux) for aircraft like the Comet, Trident and BAe146. It was a metal to metal bond used to replace rivets, which can cause fatigue problems.
