Quoting CoolGuy (Thread starter): Does the fuselage of an aircraft provide any lift? |
Quoting CoolGuy (Reply 3): Edit: Hotelmode, you beat me to it. I just wonder how significant or insignificant that amount is. |
Quoting AeroWeanie (Reply 4): I happen to have a Beech Super King Air 200 CFD solution open on my computer right now. |
Quoting Hotelmode (Reply 5): I would be interested to see if the trim postion for an identical load distribution is different on the freighters. |
Quoting CoolGuy (Reply 3): Since the top sides of aircraft seem to be more curved than the bottom, that should provide some lift (and some substantial but necessary drag). |
Quoting Hotelmode (Reply 5): I dont know, I currently fly the pax 747-400, one of my friends is now on the freighters (short upper deck) and claims there's a small but discernable difference in aircraft behaviour especially at low speed. I would be interested to see if the trim postion for an identical load distribution is different on the freighters. |
Quoting CoolGuy (Thread starter): Of course it has a shape that seeks to lessen drag to the best extent possible, but does the fuselage of an aircraft provide any lift? My guess is yes to a small degree. |
Quoting 2H4 (Reply 7): What do you think the Shorts 330/360 would be? |
Quoting 2H4 (Reply 7): Do you have any examples from other aircraft? |
Quoting Hotelmode (Reply 2): if the journey for the air over the top is longer than that underneath again "some" lift will be created |
Quoting FredT (Reply 18): The big difference from an aero point of view, as I heard it, was that the longer hump made the aircraft more area-ruled, thus decreasing mach drag significantly. |
Quoting FredT (Reply 18): discernable difference in aircraft behaviour especially at low speed. |
Quoting F27Friendship (Reply 20): The difference in behaviour is noticed in low-speed |
Quoting F27Friendship (Reply 20): Quoting FredT (Reply 18): discernable difference in aircraft behaviour especially at low speed. I reckon the 747-400 which has the longer bulb, has less separation, because there is less curvature |
