soon7x7
747 200 Side Crew Hatch
Wed Apr 02, 2008 2:42 pm
I have collected two 747 crew hatches. One from AerLingus EI-BED and another from a KLM 747. These are the four and a half foot high hatches on side, not the small square ones on top. A difference exists between the two. The KLM door has an extra type of latch on the exterior...I haven't figured it out. Almost looks like a DB COOPER lock. Can anyone shed some light on this mechanism?...Thnx in advance...j
LHRBFSTrident
RE: 747 200 Side Crew Hatch
Thu Apr 03, 2008 1:21 am
I have no REAL idea - but could it have been related to the fact that some early a/c were delivered with 1 upper deck hatch (starboard side) and were later modified for 2 upper deck hatches? (one either side: KLM and BA both did this as upper deck lounges were converted into pax-carrying cabins)
IIRC EI took delivery of some really early -100 models, whereas KLM and BA received fewer really old models and received more -100Bs and -200Bs...?
Do you have pix you could post - it would be interesting to see - and btw - WHERE did you get these from? - I want one!
[edit] wait - the DBCooper latch was on the exterior because the 727 airstairs opened outwards - but the upper deck hatches open inwards...
also KLM converted some -200Bs into SUD models (stretched upper deck) and in those a/c the hatches would have been deleted - do you know the rego of the KLM a/c it came from?
[Edited 2008-04-02 18:24:38]
[Edited 2008-04-02 18:25:01]
Viscount724
Thu Apr 03, 2008 2:03 am
Quoting LHRBFSTrident (Reply 1):
KL actually never had any 747-100s. All their early 747s were -200Bs (they were the first carrier to order the -200 and the first to put it into service). Their first 7, delivered in 1971, had P&W engines. Only their later GE-powered --200s, delivered starting in 1975, had the subsequent stretched upper deck conversion.
A.net photos show KL's early P&W -200s with just one upper deck emergency exit on the right side. However photos of the same aircraft a few years later show exits on both sides so it looks like that was a modification, probably when they installed saleable seats on the upper deck to replace the original first class lounge. If memory correct, 747s with only the one upper deck exit were limited to around 16 passengers in that cabin, while those with two exits could carry about twice as many. All of KL's later GE-powered -200Bs appear to have 2 upper deck exits from the time they were delivered.
soon7x7
Thu Apr 03, 2008 3:35 pm
I'll shoot images today and post. Did KLM actually alter existing aircraft upper lounges from the 100 style deck to the 300 style ???. I always thought they were 300 series only later to find out they were 200's...j
LockstockNL777
Thu Apr 03, 2008 5:24 pm
The image is not working overhere  Sad
soon7x7
Thu Apr 03, 2008 5:26 pm
OK, having real problem w/ these downloads, hopefully it is now correct...Green door, 747 100, EI-B
Big version: Width: 2533 Height: 3796 File size: 607kb
Big version: Width: 3930 Height: 2622 File size: 532kb
soon7x7
Thu Apr 03, 2008 5:32 pm
Quoting LockstockNL777 (Reply 5):
I can fly planes however I can't download photos!!!...I have put in for that to be deleted...sorry...J
miamiair
Thu Apr 03, 2008 6:04 pm
Quoting Soon7x7 (Thread starter):
Can you get me the part Number on the data plate? That way I can look at the drawing.
soon7x7
Thu Apr 03, 2008 6:18 pm
Miami...65B01833-205
soon7x7
Thu Apr 03, 2008 6:34 pm
Quoting Miamiair (Reply 7):
Having the part # can you trace to airframe it belonged to?...j
miamiair
Thu Apr 03, 2008 6:44 pm
Quoting Soon7x7 (Reply 9):
That is a difficult question to answer. If there is a large variations in the dahs numbers, they could have been effective for certain series (variable or line numbers) and in many cases can be either fully or one-way forward interchangeable. Sometimes a door that has the same form, fit and function can have different part numbers if there has been a modification to the part due to engineering change, service bulletin, etc.
soon7x7
Thu Apr 03, 2008 6:56 pm
Think I can get one from TWA bird if your serious..J...N93108 or N93107
soon7x7
Thu Apr 03, 2008 6:59 pm
Quoting Miamiair (Reply 10):
Understood, ...I also understand that the lever is a dissarming lever. To me it does look like it was designed much like the DB Cooper lock, so it won't or can't be repositioned in flight...
miamiair
Thu Apr 03, 2008 7:15 pm
There isn't anything on the drawing or the CMM, so that has to be a KL mod. Their DC-10s and 747s had lots of mods that were shared with Alitalia and Iberia.
soon7x7
Thu Apr 03, 2008 7:35 pm
Miami...One more ?...........I thought I saw in recent past KLM 747/200, PH-BUL with two different upper cabin roofs. Is it possible KLM removed old "hump" in trade for 400 style roof?...or...was the Reg. passed on to newr ship?...Thnx in advance...Gerard.
Viscount724
Fri Apr 04, 2008 12:36 am
Quoting Soon7x7 (Reply 3):
KL's first 7 747-200s with P&W engines were never modified. They added 10 747-200s with GE engines a few years later. They were all later modified with the same stretched upper deck as the -300 but officially remained 747-200s but with SUD added to indicate the upper deck conversion. KL also bought 3 factory-built 747-300s which were basically identical to the modified -200s..
soon7x7
Fri Apr 04, 2008 3:18 am
KLM really mods out their fleet, I just flew to AMS from JFK on PH-BFD, ASIA "Dubei", I thought it was a straight 400 series till five days later on my outbound, I noticed it had freight door on AFT port side. Thnx for feedback on this stuff...Gerard
miamiair
Fri Apr 04, 2008 11:06 am
Quoting Soon7x7 (Reply 16):
Operators can modify their airplanes to suit their needs so long as the mods are done in accordance with appoved/substantiated data. The 747 was a Combi.
Viscount724
Fri Apr 04, 2008 7:45 pm
Quoting Miamiair (Reply 17):
KL didn't modify any of their 744s to combi configuration. Their 17 747-400M combis were all originally built as combis. They also have 5 all-passenger 747-400s, plus 3 747-400ERF freighters.
Sat Apr 05, 2008 2:01 pm
Isn't the small handle for Disarming the door....
regds
MEL
soon7x7
Mon Apr 07, 2008 1:02 pm
Quoting HAWK21M (Reply 19):
Yes...so I found out...J
kl5147
Sun Apr 20, 2008 11:46 am
Maybe a bit off topic, but I might shine a light about KLM 747's upperdeck modifications.
greetz
Bart
Big version: Width: 543 Height: 563 File size: 138kb
Upperdeck modifiactions of KLM 747's (PW & GE)
"The world is just a click away!"
soon7x7
Tue Apr 22, 2008 1:55 pm
Quoting KL5147 (Reply 21):
Bart, thanxmuch for that info, tremendous expense for these type mods!...however does answer my ?'s...have any other airlines performed mods like these to a FLEET?...KLM seems to utilize all of Boings options more than other carriers, is this due to SChiphols location as a SHIPPING port (freight) to Europe?....G
kl5147
Tue May 06, 2008 7:18 pm
Quoting Soon7x7 (Reply 22):
I don't know if one can call two a/c a fleet *grinnn*, but I am pretty sure UTA had two 300 models (F-BTDG and F-BTDH) modified with an extended upper-deck (like KLM). Unfortunately I don't have any dates for their modifications.
Photo © Paul Kipping
Photo © Jan Laporte
As a sideline, Japan Airlines had even two 100 models with an extended upper-deck, but I believe they came 'factory fresh' from Boeing.
Photo © Ito Noriyuki
Photo © Takuji Sohmura
I really don't have any idea about he extra latch on the KLM door. Unfortunately I cannot see the pics you posted in this thread anymore. But when I recall the position of the window and instuctions stickers from my memory well, and compare them to to the pre-mofication pics of KLM's PH-BUO, I think your door is a right-side upper-deck door. It is likely coming from one of the ten GE-powered 206 models that have been modified in 1984-1986.
Photo © Ed Groenendijk
I am sorry I have no more information for you
rgds
Bart
point8six
Wed May 07, 2008 8:11 am
In the early 90's, BA considered converting some 747-200's to SUD's. I was told at the time that it would be about £10m per a/c and involved using a section of 757 fuselage - but I have no other info. to substantiate this. In the event, it was apparently decided by the BA board not to continue with this idea, but to order more -400s. As far as pilots were concerned, there would be no difference in flying characteristics nor cockpit layout.
kl5147
Wed May 07, 2008 8:26 am
Quoting KL5147 (Reply 23):
Oops, mistake, It should read: "UTA had two 200 models" of course
soon7x7
Wed May 07, 2008 8:47 pm
Bart, your correct as it is a right side, the lever I've been told is a door arming mechanism...sorry bout the pix...I needed space for another thread and was unaware that when you clean up images under your profile, it also kills images in the relative thread...OOOOOOOOOOOOOOOps!
LHRBFSTrident
Wed May 07, 2008 9:56 pm
Quoting Soon7x7 (Reply 26):
yeah - I've done that too Sad
just today figured out how to link images from photobucket.com and flickr.com after several experiments using the [img] [/img] UBB code under the 'Posting Help' link on a.net
off-topic, bit at least it's a 747 - here's my first linked pic:
http://i299.photobucket.com/albums/mm288/Trident2E/P4150016.jpg
Thu May 08, 2008 4:42 am
Quoting LHRBFSTrident (Reply 27):
In this case.
Who normally opens the door.Cabin crew from inside or Ground crew from outside?
regds
MEL.
kl5147
Thu May 08, 2008 8:08 am
This pic brings me to another question.
Is it correct that the maindeck doors on a Boeing 747 have strips on the upper- and lower part, which fold in when the door is opened?
LHRBFSTrident
Thu May 08, 2008 7:14 pm
Quoting HAWK21M (Reply 28):
Ground crew - this a/c was catered at 1R and 2R and both doors were opened and closed by Catering staff using the exterior butterfly handle.
http://i299.photobucket.com/albums/mm288/Trident2E/P4150014.jpghttp://i299.photobucket.com/albums/mm288/Trident2E/P4150015.jpg
The procedure varies by airline for opening the main door on arrival and departure - IIRC VS allows only groundstaff to operate the doors
Here's a YouTube video of the QF groundstaff training for 747 maindeck doors - on closing, Cabin Crew take over as the door passes into the Cabin: http://www.youtube.com/watch?v=AfVnfujHttw
Quoting KL5147 (Reply 29):
Yes - here's a pic that shows these panels (upper only) more clearly:
http://i299.photobucket.com/albums/mm288/Trident2E/P4150019.jpghttp://i299.photobucket.com/albums/mm288/Trident2E/P4150020.jpg
ok - official thread-hijack over...
Users browsing this forum: No registered users and 101 guests
