Missing Part On Vueling A320 Wing
Mon Jul 28, 2008 6:43 pm
I just flew on Vueling's EC-JGM and spotted this:
How's the missing part called in technical terminology?
EMBQA
RE: Missing Part On Vueling A320 Wing
Mon Jul 28, 2008 7:04 pm
Flap Hinge Fairing... they can be CDL, but I'm sure they take a speed or fuel hit.
320tech
Mon Jul 28, 2008 9:15 pm
We call them flap track fairings, or because we're in Canada, they're more often called canoes.
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
bond007
Mon Jul 28, 2008 10:13 pm
Ooops.
Jimbo
[Edited 2008-07-28 15:15:57]
tdscanuck
Tue Jul 29, 2008 12:04 am
Quoting 320tech (Reply 2):
They're fairly often called "canoe fairings" in the US too.
Tom.
Tue Jul 29, 2008 12:38 am
Just to add that it is "just" a fairing and as such has no structural function. It decreases drag and keeps quite a bit of dirt out of the mechanism.
CanadianNorth
Tue Jul 29, 2008 2:37 am
Flap canoe. As said it is basically just a fairing to help streamline the flap mechanism, as well as protect it from dirt etc.
Edit: If you want a true technical answer, I'm not sure what Airbus uses for terminology but in the B737-100/200 maintenance manual the official name is "flap track fairing".
CanadianNorth
[Edited 2008-07-28 19:43:15]
HS-748, like a 747 but better!
Tue Jul 29, 2008 2:24 pm
Out here...Reffered to as the Flap track fairing,used to cover the Screwjack area of the TE flap track to reduce drag in flight,can be deffered under CDL.
regds
MEL
IFixPlanes
Tue Jul 29, 2008 6:50 pm
Screwjack on a A320?
never tell an engineer he is wrong ;-)
Wed Jul 30, 2008 4:47 pm
Quoting IFixPlanes (Reply 8):
How is the TE transmission on a A320.My post was with experience on a B737.
regds
MEL
IFixPlanes
Wed Jul 30, 2008 7:59 pm
Quoting HAWK21M (Reply 9):
The picture shows a A320, so why do you answer?
BTW: question mark key still unserviceble?
Thu Jul 31, 2008 7:24 am
Quoting IFixPlanes (Reply 10):
I answer because I thought I could add some info.If people were to worry about grammatical errors & punctuation marks & not contribute even a small percentage of data,there would never be a forum or discussion.I don't state I'm the Know all around here.I too like many visit this forum to learn lots & share little & We know where we stand practically.
The purpose is to educate oneself.
True....because of a habit...I do forget to use the ? mark often,but I don't think its a crime on this forum.Whats important is the message going accross.
However I agree to what you say that the operating mechanism may be different unlike the B737 whose Flap track fairing covers the Screwjack.On the A320 Is it called by another term other than Flap track fairing/Flap canoe?
But its def for Aerodynamic purpose too.
Cheers.
regds
MEL.
Thu Jul 31, 2008 7:31 am
Quoting HAWK21M (Reply 11):
"often"?  rotfl
More like a legend.  Wink
Thu Jul 31, 2008 12:20 pm
According to the Configuration Deviation List (CDL), they are two parts, combined they are called "Flap track fairing rear top cover and tail cone"
Quoting EMBQA (Reply 1):
None, zip, zilch, zero
If the whole flap track faring was missing, fuel consumption should be increased by 3%, and TOW reduced by 1%.
Fri Aug 01, 2008 8:56 am
Quoting Starlionblue (Reply 12):
More like a legend.
Quoting Zeke (Reply 13):
Any pic of the operating mechanism they cover?
regds
MEL.
IFixPlanes
Fri Aug 01, 2008 1:53 pm
Quoting HAWK21M (Reply 14):
474218
Fri Aug 01, 2008 3:03 pm
Mel,
When I first went into product support, we corresponded with the customers by SITA or TELEX and the only punctuation they used was the . (period). Later we started using fax and it was real hard for me to break the old habit.
Additionally I took a technical writing class and we were forbidden to use the ? mark. No questions were allowed, neverything had to be written as a statement.
LY744
Fri Aug 01, 2008 3:44 pm
So while we're talking flaps, does anyone have similar (like the one iFixPlanes posted) diagrams, or is willing to write a description, of how flap actuating mechanisms work on other airliners?
LY744.
Fri Aug 01, 2008 5:08 pm
Quoting IFixPlanes (Reply 15):
Thanks.presume the torque shaft is transmitting motion to the adjacent flaps.
Quoting 474218 (Reply 16):
Mine was a bet I had on the forum for 4 yrs of not posting a ? mark.I won the bet but need to break the habit.  Smile
regds
MEL
tdscanuck
Sat Aug 02, 2008 12:33 am
Quoting LY744 (Reply 17):
On most Boeing's, you have a motor(s) in the wheel well that turn a torque tube that runs along the trailing edge. There is a gearbox at each flap fairing that picks up the torque tube and spins a jackscrew that sits inside the fairing. The flaps are mounted on carriages with a big nut that goes over the jackscrew. When the jackscrew spins, the nut moves along and takes the flap carriage with it. The carriage has rollers that ride in big rails (flap tracks) bolted to the rear spar. The profile of the flap tracks controls the flap motion. I hope that makes sense.
Tom.
LY744
Sat Aug 02, 2008 1:05 am
Quoting Tdscanuck (Reply 19):
Makes perfect sense. Sounds a lot like a power seat in a car, minus the torque tube and the hydraulic (I'm assuming) motor.  Wink
LY744.
