Quoting TISTPAA727 (Reply 4): Technically, the opposite would be negative decent, gear down. Which would be odd because two negatives make a positive, so the plane is climbing but with its gear down... |
Quoting TISTPAA727 (Reply 4): negative decent |
Quoting TISTPAA727 (Reply 4): negative decent, gear down. Which would be odd because two negatives make a positive |
Quoting RichM (Thread starter): "Positive climb, gear up". |
Quoting Max Q (Reply 10): Depends on what part of the world you're in G Shield, 'Positive Climb' Gear up is widely used outside the US. |
Quoting Goldenshield (Reply 11): Still, using RATE makes more sense than CLIMB, because RATE is states velocity, while CLIMB inherently states that something is increasing. So "positive climb" is really just "positive positive". Otherwise, you might as call descent as "negative climb." |
Quoting RichM (Thread starter): This isn't exactly going to win any awards for being a great topic, |
Quoting Swiftski (Reply 13): For airfields where the ground sweeps away at the end of the runway, rad alt isn't as reliable as pressure alt, as rad alt may show rate increasing due to lowering terrain, not due to a climb. |
Quoting Starlionblue (Reply 14): Really? I'm having fun now |
Quoting RichM (Thread starter): Shortly after rotation, airline pilots usually say "Positive climb, gear up". With that in mind, what do they say/do if there isn't a positive climb at this point? |
Quoting RichM (Thread starter): Shortly after rotation, airline pilots usually say "Positive climb, gear up". With that in mind, what do they say/do if there isn't a positive climb at this point? (stall) |
Quoting Goldenshield (Reply 9): Not to nit-pick, but the phrase is "Positive rate, gear up." |
Quoting ThrottleHold (Reply 20): Quoting Jetlagged (Reply 19): As has been pointed out above, it's not one phrase but two. PNF: "positive rate" PF: "gear up" (PNF then selects gear up) Depends on the company. In our SOP's, the PF calls "Positive climb, gear up". |
Quoting Pilotpip (Reply 21): Quoting Goldenshield (Reply 9): Not to nit-pick, but the phrase is "Positive rate, gear up." Not to nit-pick, but my first regional gig used "positive climb". I know of at least a couple US airlines that use that versus "positive rate". |
Quoting Goldenshield (Reply 22): It's pretty sad when we all start arguing over the proper way to convey the exact same message, but what would hanger flying be without it? Of course, I think we've strayed far too off-topic now. |
Quoting RichM (Thread starter): what do they say/do if there isn't a positive climb at this point? (stall) |
Quoting Kimberlyrj (Reply 26): I think a command for ‘Brace’ would be given to the cabin – that I know for sure (if the aircraft was going to make contact with the ground) |
Quoting IAHFLYR (Reply 2): a few words which will get the famous "expletive" on the accident report when transcribing the CVR.. |
Quoting Markhkg (Reply 31): The "third pilot" might be shouting, "WHOOP WHOOP PULL UP" or "DON'T SINK" ![]() |
Quoting DocLightning (Reply 29): ...followed, unfortunately, but a loud noise and then silence. |
Quoting Borism (Reply 36): What if aircraft does lift off the ground but rate of climb 0 is maintained afterwards? Granted there are no terrain, plant or artificial obstacles in the flight path, there's no reason it should crash (well, besides birds). It will continue to fly on ground effect and gain speed and gear retraction is fully justified. It isn't standard operating procedure, but it is totally considerable scenario. |
Quoting DRAIGONAIR (Reply 40): KLM SOP's: PNF: postive rate of climb PF: gear up. |
