Quoting Jetstar (Reply 3): I believe there were 2 small micro speakers mounted in the seat panel where you plugged in the headsets. The headsets were nothing but hollow tubs that transmitted the speaker sound through the tubes to the ear pieces. If the cabin was quiet, you could place you ear next to the audio panel and hear the sound from the holes where the headsets plugged in. |
Quoting AirframeAS (Reply 5): It is surprising that I still remember these kinds of audio systems. |
Quoting Jetstar (Reply 9): In the early days of headsets, they had to be rented and returned after the flight, so with the hollow tube type used, this was no problem, |
Quoting Nomadd22 (Reply 8): Those things were about 1/4 of a step above tins cans and strings. But, there wasn't much available in cheap, light headphones back then. |
Quoting Andz (Reply 14): If I recall correctly I read in an inflight magazine that the rental was to cover music royalties. |
Quoting Jetstar (Reply 9): I think to prevent passengers from using their own walkman headsets, some airlines used the 2 prong headset. |
Quoting Mender (Reply 15): The look on the stewardess's face when she saw smoke apparently coming form the blokes ears was priceless. |
