kimon
SQ006 PVD RWY Identification
Fri Feb 26, 2010 7:50 pm
Had the crew not ignored that the PVD remained shuttered,whould it have saved them from disaster?
The failure of the PVD to unshutter indicated to the flight crew that the aircraft was not at the correct location for takeoff.
Does PVD assist the crew in determining whether the aircraft is on the correct runway or ONLY to provide steering guidance under low visibility conditions for centreline tracking and not to identify the correct location for takeoff?
What is the difference between position and location?
Is PVD merely provide reversionary visual guidance and has no role in other ground operations?
AFM states that PVD will shutter /unshutter dependent upon whether the aircraft is in a position for takeoff or not.
CVR SQ006:
CM-2 "PVD hasn't lined up ah"
CM-1 "Yeah we gotta line up first"
CM-3 "We need forty five degrees" (PVD only arms within 45 degrees of the runway heading).
CM-1 "Not on yet er PVD huh never mind we can see the runway,not so bad" (After lining up,PVD still shuttered as it was not within the valid localizer region for RWY 05L).
EICAS message>PVD SYS CAPT F/O indicates that
*ILS frequency not correctly selected
*Aircraft not withing the valid localizer region
*Aircraft heading not with 45° RWY HDG
*PVD has malfunctioned
*An aircraft is blocking ILS signal
[Edited 2010-02-26 11:56:45]
Dum Romae consulitur, Saguntum expugnatur
Fly2HMO
RE: SQ006 PVD RWY Identification
Fri Feb 26, 2010 8:19 pm
Quoting kimon (Thread starter):
shuttered
excuse me? not sure what context your using that word with.
In a nutshell, yes
Mir
Sat Feb 27, 2010 11:34 pm
Ok, I've thought about this for a bit, done some Googling, and I'm still wondering:
What's a PVD? That's a term I've never heard before.
-Mir
Fabo
Sun Feb 28, 2010 12:48 am
Para Visual Display. It has been discussed here lately to the detail.
The light at the end of tunnel turned out to be a lighted sing saying NO EXIT
411A
Sun Feb 28, 2010 2:07 am
All very interesting, however...SQ did not order PVD's as a line item on their aircraft...IE: not installed.
kimon
Sun Feb 28, 2010 8:36 am
Yes,All SQ 744 pax are equipped with PVD but not freighters.
See SQ AFM + Boeing supplement on PVD.
SQ006:Upon entering the wrong runway, the flight crew had neglected to check the paravisual display (PVD).
[Edited 2010-02-28 00:41:38]
kimon
Sun Feb 28, 2010 8:38 am
http://aerowinx.com/html/gallery04.html
As all BA fleet is equipped with PVD thus RVR minimums is 75 metres as opposed to non-PVD fleets which have RVR minimums of 125 metres.
[Edited 2010-02-28 00:43:23]
[Edited 2010-02-28 00:43:55]
kimon
Sun Feb 28, 2010 8:55 am
I wish I could fit PVD on the coaming of my YM 2003 Jeep Grand Cherokee!
It is the most aesthetically pleasing item on the FD.
Non-PVD FDs look plain like a Xmas tree without Dolly Parton's bells-and-whistles!
mandala499
Sun Feb 28, 2010 10:14 am
Kimon,
Not bad 3 topics on PVD in 2010 by you... and each one keeps talking about the same thing...
You have already shown us that QF maintenance picture, which shows the PVD in a maintenance check, not itself in action... in each of the 3 topics...
Plus, talking about reducing RVR has been mentioned in 2...
And the SQ006 has been mentioned in 2.
For me, I have simpler rules... if I cannot have adequate visual reference (either centerline lights or edge lights) in poor visibility, I don't power up for take off... simple.
Quoting kimon (Reply 7):
I can also say that PVD equipped FDs is an extra maintenance cost item for most carriers... and makes the FD look like a christmas tree with too much candy hung from it...
Gimme an EVS overlay on an HUD instead of a PVD any day of the week...
Mandala499
411A
Sun Feb 28, 2010 11:31 am
Quoting kimon (Reply 5):
Require documentation to varify...not just your 'opinion'.
71Zulu
Sun Feb 28, 2010 7:08 pm
Seems logicaI that since the crew mentions the PVD on the transcript that they had it.
http://aviation-safety.net/investigation/cvr/transcripts/cvr_sq006.php
23:15:52 CAM-1 It going to be very slippery I am going to slow down a bit, slow turn here
23:15:53 CAM-2 Turning that
23:16:07 CAM-2 And the PVD hasn't lined up ah
23:16:10 CAM-1 Yeah we gotta line up first
23:16:12 CAM-3 We need forty five degrees
23:16:15 CAM-2 I see, excellent man
23:16:16 CAM-1 Yah
23:16:23 CAM-1 Not on yet er PVD huh never mind we can see the runway, not so bad. Ok, I am going to put it to high first. OK ready eh, so zero one zero is from the left lah Ok
23:16:27 CAM-2 Ok
kimon
Sun Feb 28, 2010 7:53 pm
Hi Mandala499,
EVS?
Which aircraft will be equipped with HUD?
Many thanks!
Kimon
mandala499
Sun Feb 28, 2010 9:54 pm
Quoting kimon (Reply 11):
EVS?
You can buy and add those HUDs with EVS on a lot of aircraft... at least HUDs...
Has been available on 320s and 737s for a while !
Slap that and EFB with moving map, and PVD's usability is limited to lowering the take off limits only...
Now, the thing is, all these stuff costs money to buy and maintain, and are rarely used... and the regulations regarding their uses need to catch up...
mandala499
Users browsing this forum: Aaron747 and 14 guests
