rchapin
Pilot Survey
Wed Nov 03, 2010 6:06 am
Hello pilots,
I am an aviation student at Eastern Michigan University.
I need to survey a "large number" of pilots for a research assignment that's due on November 10. Your answers to this short survey would be very helpful.
Go To My Pilot Survey
http://www.surveymonkey.com/s/RH79CXZ
Please check that out if you can help.
Robert
tb727
RE: Pilot Survey
Wed Nov 03, 2010 1:50 pm
Quoting rchapin (Thread starter):
Anything to help out a fellow Eagle!
rchapin
RE: Pilot Survey
Wed Nov 03, 2010 2:52 pm
Quoting tb727 (Reply 1):
Wow, awesome
26 pilots responded so far.   Keep em coming. The more the merrier!
Fly2HMO
RE: Pilot Survey
Wed Nov 03, 2010 10:31 pm
Responded. What an odd survey might I add.
rchapin
RE: Pilot Survey
Wed Nov 03, 2010 11:07 pm
Quoting Fly2HMO (Reply 3):
Thank you for participating.
Feel free to ask me about any oddities.
Fly2HMO
RE: Pilot Survey
Thu Nov 04, 2010 12:49 am
Quoting rchapin (Reply 4):
Well it just seemed like mostly random questions. Couldn't really make out what was the purpose of it.
Also, it wouldn't hurt to add the other licenses as well, you were missing ATP, CFI, CFII, MEI, AGI etc etc (yes I was too lazy to type in the "other" field   )
rchapin
RE: Pilot Survey
Thu Nov 04, 2010 1:05 am
Quoting Fly2HMO (Reply 5):
This is good because the questions won't lead or bias your thinking. The "purpose" is to collect some honest answers that I can present in the context of the hypotheses that I am testing. The results may confirm or refute some common beliefs.
This is just a matter of keeping it simple. When I look at the results of the question about long haul flights, the CFI isn't as relevant as private vs. commercial.
ATP is already included. You can look back and change your answer. Did you mean A&P?
Fly2HMO
RE: Pilot Survey
Thu Nov 04, 2010 3:13 am
Quoting rchapin (Reply 6):
Ah, reverse psychology. Smart man.
O really? Guess I forgot. Disregard.
AAR90
RE: Pilot Survey
Thu Nov 04, 2010 3:39 am
#3 - miles to "base airport." I have 5 "base airports" that I am responsible for. Obviously the distance varies, but there is no option for various or multiple distances (I avoid LAX if at all possible).
#4 - minutes to clear security. Probably better to as AVERAGE minutes to clear security. Depending upon the airport and the personnel on duty, it can vary from a couple of minutes to 15 or more minutes.
rchapin
RE: Pilot Survey
Thu Nov 04, 2010 1:09 pm
Quoting AAR90 (Reply 8):
Is that like not having a base airport?   I'm just looking for how much of a commute is involved.
AAR90
RE: Pilot Survey
Thu Nov 04, 2010 3:19 pm
Quoting rchapin (Reply 9):
Probably, but that is because we don't have a "base airport." In AA's system the LAX Crew Base is the administrative designation; however, "LAX based" pilots are responsible for trips that start/end at the "Satellite" crew bases: LAX, ONT, LGB, SNA and SAN.
Depending upon the time of day, day of the week & satellite base, my commute can be anywhere between 25 minutes and 4+ hours. That is just the drive times to the parking lots. Transit time from parking lot to inside the terminal can be an additional 5 to 45+ minutes.
rchapin
RE: Pilot Survey
Thu Nov 04, 2010 6:34 pm
Quoting AAR90 (Reply 10):
Ah! If you're not required to "touch base" then put the average one-way distance for a drive to work.
lowrider
RE: Pilot Survey
Thu Nov 04, 2010 6:48 pm
With regards to the base airport question, there are several carriers that home base pilots. We simply airline to where the plane is and start our trip there. I used an average number, but in reality, I could start my trip 300 miles away one month,
and travel 3000 miles back home at the end of the trip. I simply put in an average number.
Proud OOTSK member
rchapin
RE: Pilot Survey
Thu Nov 04, 2010 8:37 pm
Quoting Lowrider (Reply 12):
The average is good.
rchapin
RE: Pilot Survey
Sat Nov 06, 2010 11:38 pm
I am uncertain if I will be able to leave the survey open after this weekend, so I'm giving it a weekend bump.  Smile Ideally, I would like to keep it open until the final drafts are due near the end of the month. However, drafts are also due this coming Tuesday and Wednesday.
[Edited 2010-11-06 16:39:08]
rchapin
RE: Pilot Survey
Tue Nov 09, 2010 5:02 am
The survey was a huge success and is now closed.
186 helpful pilots submitted survey answers!
I will post the results in a new thread in mid December when the analysis and drafts are complete.
Thanks again everyone!
XFSUgimpLB41X
RE: Pilot Survey
Wed Nov 10, 2010 12:23 am
I believe I took it before it was deleted on APC. Hope it helped and look forward to see what your final outcome is.
Chicks dig winglets.
Users browsing this forum: DFW17L, themathguy and 29 guests
