Quoting Stitch (Reply 4): Daniel Tsang at http://www.aspireaviation.com claimed that EK sees a fuel burn of 2.8L per 100km for both the 777-200LR and 777-300ER. |
Quoting trex8 (Reply 3): 772/A343 6900kg/hr A333 6000kg/hr A346 8900kg/hr 744 11100kg/hr 77W 8100kg/hr |
Quoting zeke (Reply 8): That number is rubbish unless the assumptions associated with them is also listed. |
Quoting sunrisevalley (Reply 9): From a flight plan ORD-AKL for a 77L with a TOW of about 318t the fuel burn at cruise was 100.171t for 15-hours. |
Quoting coopdogyo (Reply 13): According to a Boeing reference guide I have the 777-200LR burns 3.2 liters per 100 passenger km over and 6,000nm(11,110km) trip and the 777-300ER burns 2.9 liters per 100 passenger km over the same trip. |
Quoting zeke (Reply 14): Quoting coopdogyo (Reply 13): According to a Boeing reference guide I have the 777-200LR burns 3.2 liters per 100 passenger km over and 6,000nm(11,110km) trip and the 777-300ER burns 2.9 liters per 100 passenger km over the same trip. For the 77L that works out to be 8,476 kg/hr assuming bog standard Boeing 301 pax For the 77W that works out to be 9,314 kg/hr assuming bog standard Boeing 365 pax |
Quoting Stitch (Reply 12): Also from PPRune, Trip Fuel for an EK 777-200LR doing DXB-LAX would be around 121.5t with a ZFW of 209t and a TOW of 342t. |
Quoting arniepie (Reply 15): Far for me doubting your numbers but aren't you mixing up kilo's with liters? |
Quoting zeke (Reply 20): Yep I did, my bad, good catch. |
Quoting iwok (Reply 21): Any idea how these values change during the flight. I.e. there is a certain fuel usage during, takeoff, clim, initial cruise and cruise just before defending to land. I have got to think that as fuel is consumed that fuel burn drops because gross weight is dropping. |
Quoting ferpe (Reply 23): What do you want to know and for what frame variants? As I have a cruise drag model which is not to far off I could check a couple of numbers for you but not all these types and the different flight modes. |
Quoting Stitch (Reply 22): He noted that for a 777-300ER it varied from a low of 6,500kg per hour to a high of 10,500kg per hour across the flight. And for a 747-400, it varies from a low of 9,000kg to a high of 13,000kg per hour. |
Quoting trex8 (Reply 26): Is it reasonable to assume a 777F burns fuel more like a 77W than 77L?? |
Quoting philippelouis1 (Thread starter): What is the fuel burn rate of B777-200LR/300ER |
Quoting trex8 (Reply 32): I guess my brain has trouble wrapping around the idea that a 77L which has 40 + tonnes more MTOW , even with a better wing and maybe engines, has the same or slightly better fuel burn than a 772ER! |
Quoting dhr (Reply 36): Cruise Speed, Cruise Altitude and Cruise Fuel Flow (Gal or lb per hour) Climb speed, Vertical Speed and Climb Fuel Flow (Gal or lb per hour) Descent Speed, Vertical Speed, and Descent Fuel Flow (Gal or lb per hour) |
Quoting ChaosTheory (Reply 37): our brain has trouble for good reason because it is not true. Both trip fuel burn and fuel burn per seat are higher for the 77L over all sector lengths. Someone has been feeding you porkies. I wonder who? |
Quoting FriscoHeavy (Reply 38): The 77L is actually more efficient after "X" number of miles (4,000 miles?) -- Can't remember the exact number, but it's not porky, it's true. |
Quoting ChaosTheory (Reply 39): I've run these through our performance apps for the 772ER and 772LR both with GE90 engines and zero wind. Remember they both have the same seating capacity. Sector length and trip fuel burn: |
Quoting Stitch (Reply 40): His comments were that the improvements in TSFC, propulsive efficiency, and airframe L/D more than negated the drag penalty of the extra structural weight of the 777-200LR. And this was before the engine and aerodynamic PiPs to the 777-200LR. |
Quoting Stitch (Reply 40): Posted just for background purposes: widebodyphotog was the member who noted the 777-200LR had 3% better fuel burn/unit payload than 777-200ER at ranges beyond 2,000nm (which I believe was when both were operating with the design payload and range of the 777-200ER). His comments were that the improvements in TSFC, propulsive efficiency, and airframe L/D more than negated the drag penalty of the extra structural weight of the 777-200LR. And this was before the engine and aerodynamic PiPs to the 777-200LR. |
