YokoTsuno
How Is Tailwind And Headwind Measured?
Tue May 24, 2011 1:55 pm
How is tailwind and headwind actually measured? You can't possibly derive that from the forward pointing pitot tubes alone, can you?
boeingfixer
RE: How Is Tailwind And Headwind Measured?
Tue May 24, 2011 3:34 pm
Quoting YokoTsuno (Thread starter):
It's done with Inertial Reference Units(IRU's). This is the heart of most modern airliners and provides attitude and direction information to the pilot and flight management computers. In simple terms it knows the aircrafts position, speed, heading, drift, course etc. and can extrapolate wind information from this data.
John
BE77
Tue May 24, 2011 5:52 pm
Quoting boeingfixer (Reply 1):
..or on the windspeed / wind component page of most Aviation GPS machines, especially if they are tied into the airspeed and external air temp data.
Old school is by taking the groundspeed calculated by time between two points or between navigation beacons (VORs, NDB;s etc), calculating true airspeed from airspeed, temp, and altitude data, then adding in the correction for drift required to maintain the desired track, then plotting all that on the wind side of the whiz wheel, and voila, it's done. Pre GPS some of us could actually do that fast enough for the answer to be relevant to the current flight. Of course, I also remember using a slide rule, rotary telephones, leaded car gas, and a whole truckload of other stuff I DO NOT MISS!
Mir
Wed May 25, 2011 6:36 am
Pure headwind or tailwind is just groundspeed minus true airspeed. If you get a positive number it's a tailwind, a negative number is a headwind. So if you're flying at 450 knots and your groundspeed is 480 knots, you've got a 30 knot tailwind.
But since the wind is rarely directly on the nose or the tail, other factors like heading and track start to come into play. The formula for headwind and tailwind still works, but the 30 knot tailwind would now just be a component of the total wind.
-Mir
B747FE
Wed May 25, 2011 8:55 am
No, you can't. boeingfixer got it right...the IRS/GPS or INS in old birds take care of that.
However when in long flights in the middle of nowhere and boredom kicks in, nothing like cross-checking your instruments with a good old CR3.
Wind triangle, anyone?
B747FE.
Wed May 25, 2011 9:45 am
Quite. That only gives you indicated airspeed. Aerodynamically, the aircraft doesn't care if it is in in a tailwind or a headwind. It just cares about airspeed.
YokoTsuno
Wed May 25, 2011 2:02 pm
Thank you very much for the anwers
Quoting be77 (Reply 2):
Are you referring to these?
http://en.wikipedia.org/wiki/Rotary_dial
Really? So you dial the guy who does the calculation for you .
sprout5199
Thu May 26, 2011 1:59 pm
or having to get up and change the channel on the TV. When I was young, I asked my Dad to buy a TV with a remote, his answer "we already have one, I just have you change the channel for me"
Dan in Jupiter
BE77
Thu May 26, 2011 7:18 pm
Quoting YokoTsuno (Reply 6):
Heh heh - yes, one of those. I even spent a summer job fixing / refurbishing them at the local phone co warehouse.
Problem with your idea of calling someone to do the calculation though is that as strange as it sounds, we didn't have cell phones either. Does anyone know if there is an Iphone app to let you dial using rotary movement, hopefully with the clicking sounds and all?
Quoting sprout5199 (Reply 7):
How on earth did I not remember that...of course, we only had two channels (CBC English, and CBC French), we we only had to walk over to the TV to turn it on or change the volume. (And yes, it was uphill both ways through 6 feet of snow to get to school!).
Users browsing this forum: CrewBunk, Flow2706, Max Q, Woodreau and 11 guests
