Quoting Stitch (Reply 1): I believe the 747-8F has the same upper deck as the 747-400F (and earlier 747Fs) so it might just be a customer configuration decision. |
Quoting LAXintl (Reply 4): While I don't know what photo you are looking at... |
Quoting Max Q (Thread starter): Has the actual usable space inside this upper deck been reduced this much and if so, what is behind the bulkhead ? |
Quoting Max Q (Thread starter): Perhaps Wilco737 can clear this up ! |
Quoting LAXintl (Reply 4): While I don't know what photo you are looking at, for all the -400 freigthers I've flown, right behind the cabin seats would be the bulk head door that leads to the bunks. Most typically there are 4 beds, double stacked. |
Quoting lowrider (Reply 3): Get in a few more tall pallets. Beneath the upper deck, you are limited to 96 inch tall pallets. The further back the upper deck extends, the further aft this restriction extends. |
Quoting tdscanuck (Reply 6): It's not as bad as you think...look at the lower left corner of the picture in Reply 5. That's a door hinge...that door opens up into a multi-bunk space behind that bulkhead. Also, if you stand in the position this photo was taken and turn 180 degrees, the fwd bulkhead is much farther forward...the seating area on the right side is much larger than on the left. The forward left side is the galley. |
Quoting Max Q (Reply 8): That makes a lot of sense, is that really the case ? |
Quoting Max Q (Reply 8): Understand, would like to see a picture taken from that aspect. |
Quoting Max Q (Reply 8): Overall though, it is surprising how much smaller this upper deck space is compared to the classic (freighter or pax version) |
Quoting tdscanuck (Reply 10): If you mean this particular spot on the upper deck, I defer to those with more -400F experience. The overall area of the upper deck is no different on the -400F and the -8F. |
747-200F/400F - 10 ft pallet capability |
![]() Photo © Vasco Garcia | ![]() Photo © Joe Corrigan |
![]() Photo © Vasco Garcia | ![]() Photo © Jonathan Rankin |
![]() Photo © Wojtek Werpachowski | ![]() Photo © Craig Murray |
