Chamonix
Lahso Questions
Sun Dec 11, 2011 10:26 am
Is there a list of LAHSO-approved airports?
How does one get LAHSO-rated?
Is it the trickiest of all techniques?
Can one do a CAT III B LAHSO?
windshear
RE: Lahso Questions
Sun Dec 11, 2011 12:26 pm
I never fully understood what it means besides what the acronym stands for, I am not sure what the operation requires of the pilot.
Boaz.
tb727
RE: Lahso Questions
Sun Dec 11, 2011 3:36 pm
Quoting Chamonix (Thread starter):
As far as I can remember the company has to have it in their op-specs. It's not necessarily tricky but it's not something I want to do. A lot can go wrong. At my company we are not allowed to accept a LAHSO except at CYYZ but since we hardly go there, it's not really an issue for us. If it is being broadcast on ATIS that they are doing the LAHSO operation, when we check on with approach or tower we just advise we can not accept them and it's never been a problem.
Web500sjc
RE: Lahso Questions
Sun Dec 11, 2011 4:11 pm
LAHSO= land and hold short operations. it is used at airports where there are two intersecting runways, and the control tower would like to use both of them.
there is no LAHSO rating, but it falls to the pilot to decide if they can take the clearance. once you accept a LHASO clearance it is binding and it essentially gives you a shorter runway to land on.
My guess is no, because I believe LHASO is only used in a visual conditions (it is kind of hard to stop before a runway if you can't see it)
lowrider
RE: Lahso Questions
Sun Dec 11, 2011 4:28 pm
No, on a CAT 3B landing the ILS critical area needs to be kept clear, having traffic rolling through an intersecting runway would violate that.
DiamondFlyer
RE: Lahso Questions
Sun Dec 11, 2011 4:31 pm
Quoting web500sjc (Reply 3):
Doesn't have to be a runway that you hold short of. Can be a taxiway as well.
-DiamondFlyer
Mir
RE: Lahso Questions
Sun Dec 11, 2011 7:33 pm
Quoting lowrider (Reply 4):
I wouldn't accept that clearance anyway - if I'm going to be expected to stop before a certain point, I want to be able to see that point. I wouldn't accept the clearance unless the weather was basic VFR or better. Of course, it's all academic, since my current company doesn't allow us to accept the clearances at all (even though we can get down and stopped in 3000 feet easily, making LAHSO an absolute non-event), but if I were flying on my own....
-Mir
AAR90
RE: Lahso Questions
Sun Dec 11, 2011 8:13 pm
No. All an airport needs to get LAHSO ops approval from FAA is an acceptable reason and proper paperwork.
There is no "LAHSO rating."
No. The available runway is reduced.
No. AIM indicates 1000/3 as minimum weather required for LAHSO ops.
NBGSkyGod
RE: Lahso Questions
Mon Dec 12, 2011 5:05 pm
Quoting AAR90 (Reply 7):
Actually its a lot more complicated than that, we thought about getting it for our airport but decided against it, since it required meetings with the airport, pilot groups, airline groups, the FAA, and a certification process all to allow two cessnas to land on intersecting runways.
bond007
RE: Lahso Questions
Tue Dec 13, 2011 12:35 am
My last company didn't allow any LAHSOs. Not sure of the exact statistics, but AFAIK, they did show several incidents a year before airlines started to refuse them.
Even when flying GA, I often refuse because it's simply one risk that I can exclude very easily and my mind doesn't need to be focused on stopping shorter than I have to.
It's mostly psychological when I do accept them and keep thinking "I must stop", since often the intersection is only reducing the runway length by 1000' or so ... out of 8000' ... not exactly a struggle for a Baron or C172 - but somehow it's still in my mind bugging me
Jimbo
c172akula
RE: Lahso Questions
Wed Dec 14, 2011 2:28 pm
LAHSO operations were very common when I was training and then instructing at YYC from 1999-2004 (all of YYC's 3 runways intersect another runway). However it now appears that these operations no longer happen, or are very rare.
I do remember AA being the first airline that I heard on the radio indicate that they could not perform a LAHSO for ATC (probably around 2003).
chrisco1204
RE: Lahso Questions
Thu Dec 15, 2011 1:34 am
There is no LAHSO rating. Any pilot can perform a LAHSO operation.
DiamondFlyer
RE: Lahso Questions
Thu Dec 15, 2011 2:26 am
Quoting chrisco1204 (Reply 11):
As long as they aren't a student pilot.
-DiamondFlyer
CosmicCruiser
RE: Lahso Questions
Thu Dec 15, 2011 9:41 am
I don't see the issue. We do it, though not often but the criteria are such that you shouldn't compromise safety nor use max braking. we have a list of requirements and it eliminates most gotchas.
mark2fly1034
RE: Lahso Questions
Thu Dec 15, 2011 3:20 pm
I train out of Daytona and have been asked it once. We took it but we had like 4000 feet to stop... we only needed like 600 so it was not a problem if I fly by myself I do not think i would take it.
26point2
RE: Lahso Questions
Thu Dec 15, 2011 4:34 pm
As a general rule we decline when asked...why take on the liability?
Any ATCers out there who can tell us what percentage of guys accept LAHSO requests? I would think it's pretty low.
packcheer
RE: Lahso Questions
Thu Dec 15, 2011 5:26 pm
How common are they at major airports?
CLT for example? would LAHSO be a common thing there, or just not an uncommon thing, or is it completely rare?
Ward86IND
RE: Lahso Questions
Fri Dec 16, 2011 2:18 am
At ORD it used to be standard practice for 22R LAHSO 9R/27L. Like 6600 feet available. Since 9L/27R has been in open I don't think they do it much anymore, but correct me if I'm wrong.
AAR90
RE: Lahso Questions
Fri Dec 16, 2011 6:12 am
Quoting Ward86IND (Reply 17):
Correct. We (AA & UA) used to get that regularly until the airlines/unions/FAA came up with a more "structured" (read: restrictive) LAHSO procedures for airline use. When the "new" procedures came out AA pilots could only accept LAHSO to specific runway combinations (and acft configurations) that are listed in our AA airport pages. At ORD, that means Rwy-28 LAHSO Twy-S (IIRC) is about the only remaining combination (don't have my Jepps with me). Rwy-32R has been "shortened" so that LAHSO has gone away as well. Still regularly see it in use at DFW and I know we have a number of other places with LAHSO is listed.
Quoting NBGSkyGod (Reply 8):
The specific steps an airport has to go through are complex (this IS gov't we're talking about); however, the basic "this is what it is" policy is not... especially when trying to explain the basics of LAHSO to the uninitiated.
bond007
RE: Lahso Questions
Fri Dec 16, 2011 4:11 pm
Quoting DiamondFlyer (Reply 12):
Yes, AFAIK this was a change in 2000, which was part of several changes to LAHSO. During my flight training this was not a restriction.
Jimbo
Users browsing this forum: Baidu [Spider], boacvc10, northstardc4m and 11 guests
