Northwest727
MD-11 "Bent" Fuselage In Flight?
Sat Mar 03, 2012 11:11 pm
Hi everyone,
While I was looking at pictures of MD-11s, I noticed that in flight, the fuselage appears to "sag" down ahead of and behind the wings. Am I just going out of my mind and seeing things, or is this actually the case?
Photo © Szabo Gabor
Photo © Szabo Gabor
Photo © Ben Wang
RE: MD-11 "Bent" Fuselage In Flight?
Sun Mar 04, 2012 1:13 am
Quoting Northwest727 (Thread starter):
It's not an illusion. Fuselages definitely sag like that. Just like a long plank would sag if you put it crosswise over an i-beam.
Horstroad
Sun Mar 04, 2012 2:00 am
Yes fuselages bend. But it is hardly visible from this perspective the images show, at least I can not see it. Except for the curvature behind the wings. But if that's what you mean, that's just like the aft fuselage of the MD-11 is shaped, even on the ground.
This effect is well visible in this photo
Photo © Daan Krans - AirTeamImages
DocLightning
Sun Mar 04, 2012 3:06 am
The 777-300/ER is visibly bent in flight.
DocLightning
Sun Mar 04, 2012 7:38 am
Photo © ShaneShanghai
Photo © William T Shemley
Photo © Terry Wade
Photo © Didier JH Goursolas
n901wa
Sun Mar 04, 2012 3:20 pm
Its a carryover from the DC-10. Both the DC-10 and MD-11 had this bend/taper. From what I was told was it gives the nbr 2 eng a nose up angle with the spacing between the trunk and the top of the fues equal. You can see it in this photo I took in HNL. and you can see it in this photo I took of the MD-11 and use the hangar opening as a straight line. HTH
Last WAL/DAL DC-10 out of HNL
Big version: Width: 2970 Height: 2076 File size: 429kb
812 in LAX
[Edited 2012-03-04 07:37:37]
Fabo
Sun Mar 04, 2012 8:33 pm
Very visible on 757-300.
Viscount724
Sun Mar 04, 2012 9:06 pm
I think what you're seeing is the way the upper fuselage begins to slope slightly downward starting slightly ahead of the rear door, as on the DC-10.
aviopic
Sat Mar 10, 2012 8:26 am
I've no information about you and the state of your mind
But the other two are both correct.
It's easy to play tricks on the human mind with photography(or with vision in general) as every photographer knows.
And a fuselage does distort as can be clearly seen in a photo I made years ago.
Photo © Willem Honders
CosmicCruiser
Sat Mar 10, 2012 10:53 am
Quoting Viscount724 (Reply 7):
I agree
musang
Sat Mar 10, 2012 11:11 am
Interesting thread.
I think there are a couple of different phenomena being discussed here though. I think the original post referred to the belly of the MD-11. Later mention of the MD-11 / DC-10 upper rear fuselage below the no. 2 engine refers to a design feature, as n901wa says, which is one of the type's signature visual characteristics.
Personally, I don't see a "bent" fuselage belly profile on the 757, and suggest that what can be seen is the parallel but unaligned belly profile ahead and aft of the wing. The rear fuselage is a deeper cross-section that the forward i.e. behind the wing/fuselage fairings it doesn't return to the same depth as the fwd fuselage. The 727 is the same.
However, the 777-300 pics are interesting. Displaying them large and placing a ruler on the screen, there does seem to be a mis-alignment of the belly fwd vs. aft of the wing. It does appear bent. The area for scrutiny is near the centre of the frame in each of the 777-300 pics, taken with telephoto lenses, so there's minimal peripheral distortion, so brilliantly illustrated in aviopic's wide-angle Caravan image.
Other candidates for this phenomenon may include the A340-600 and DC-8-61/3/71/73 so I'd look for long focal length, side profile shots.
I once heard that large ships e.g. supertankers are built with a bent hull to take account of the curvature of the earth, and know that the towers of suspension bridges (e.g. Humber, Severn, Verrazano Narrows etc.) are out of parallel for the same reason. However I would not think this is a consideration in aircraft design!
Regards - musang
zanl188
Sat Mar 10, 2012 11:58 pm
We can't have a "Does the fuselage bend?" thread without the containership flexing video.
So without further ado....
http://www.youtube.com/watch?v=qEkErF51Uxg&feature=related
Flighty
Mon Mar 12, 2012 1:15 am
A fisheye effect could also be doing this. You would have to true the image against a known straight object, unless image processing is smart enough to do this "holistically." Which I am not sure about, if we are talking about hundreths of a degree.
CosmicCruiser
Mon Mar 12, 2012 2:31 am
no manual diagrams show nor text mention this.
Northwest727
Mon Mar 12, 2012 2:01 pm
Quoting aviopic (Reply 8):
Sometimes, I wonder about myself
Users browsing this forum: Fiver and 10 guests
