MUC79
Data On Cabin Floor Area Of Commerical Aircraft?
Fri May 11, 2012 1:02 pm
Hi!
I am playing around with different seat layouts of commercial transport aircraft for my resaerch.
However, I am struggling in finding values for the floor space available for the cabin monuments for different aircraft types. The only values I could find so far are:
A380-800: 478 m^2
747-400: 321 m^2
(http://en.wikipedia.org/wiki/Airbus_A380)
Ok, I could measure the floor area from blueprints etc., but at the moment I still have hopes to circumvent this cumbersome exercice....
It would be great if you could provide me with some more numbers or sources.
Thank you very much in advance!
[Edited 2012-05-11 06:07:32]
ferpe
RE: Data On Cabin Floor Area Of Commerical Aircraft?
Thu May 17, 2012 2:46 pm
Here is what I have, if others have better values please chip in:
Aircraft........................787-8...787-9...787-10..A350-800..A350-900..A350-1000..777-200..777-300ER
Maximum cabin width....5,49....5,49.....5,49.........5,61........5,61.........5,61...........5,87........5,87
Cabin length.................42,3....48,4.....54,5.........45,5........51,8.........58,8...........48,4........58,5
Cabin floor m2.............232,2...265,7....299,2......255,0.......290,6.......329,8........283,9........343,4
Aircraft........................777-8X..777-9X..767-300..A330-200..A330-300..A340-300..A340-500..A340-600
Maximum cabin width....5,97....5,97.....5,49.........5,28........5,28.........5,28...........5,28........5,28
Cabin length.................53,3....61,1.....40,0.........45,0........50,35.......50,35........54,65........62,05
Cabin floor m2.............318,0...364,7....188,8......237,6.......265,8.......265,8........288,6........327,6
CM
Thu May 17, 2012 4:08 pm
Quoting MUC79 (Thread starter):
Since you are working on seat layouts, be a bit careful with Ferpe's numbers as they do not account for body taper. The aft-body taper varies significantly between aircraft, with some losing many seats in this area (777/747/A330/A340), others losing very few (787) and some losing none (767/A350). Forward body taper affects some aircraft as well (747/A330/A340), but to a much lesser degree than the aft body, and the impact in the forward body is usually highly dependent on what type of cabin product is being installed.
Have fun!
Flighty
Fri May 18, 2012 1:49 am
Apologies, much of this is definitely a guess or wrong. But it is what I was able to find some years back.
Code IATA Code CabWidth CabLength CabArea
- A319 319 3.70 23.78 87.99
- A321 321 3.70 34.44 127.43
- A330 333 5.28 50.35 265.85
DO-328 D38 2.50 12.00 30.00
L-1011 L10 5.77 45.11 260.28
SF-340 SF3 2.50 14.00 35.00
- B-777 777 5.86 49.10 287.73
- MD-11 M11 5.71 46.51 265.57
- MD-80 M80 3.14 30.60 96.08
- MD-87 M87 3.14 21.85 68.61
- MD-90 M90 3.14 32.23 101.20
-1011-5 L15 5.77 37.31 215.28
-737-2C 73C 3.54 18.00 63.72
300-600 306 5.28 40.70 214.90
320-1/2 320 3.70 27.51 101.79
737-1/2 732 3.54 18.00 63.72
737-5/6 735 3.54 19.72 69.81
737-7/L 73G 3.54 24.13 85.42
737-8/9 738 3.54 29.97 106.09
747-2/3 742 360.00
767-2/E 767 4.72 33.93 160.15
767-3/E 763 4.72 40.36 190.50
B-717-2 717 3.14 23.38 73.41
B-727-2 727 3.54 35.00 123.90
B-737-3 733 3.54 22.12 78.30
B-737-4 734 3.54 25.16 89.07
B-737-9 739 3.54 32.61 115.44
B-747-1 741 360.00
B-747-4 744 s s 380.00
B-747-F 74F 360.00
B-757-2 757 3.54 36.09 127.76
B-757-3 753 3.54 43.21 152.96
B-767-4 764 4.72 46.86 221.18
B-I900 BE1
CRJ-100 CR1 2.57 14.76 37.93
CRJ-200 CR2 2.57 14.76 37.93
CRJ-700 CR7 2.57 17.28 44.41
CRJ-900 CR9 2.57 21.16 54.38
DC-10-1 D11 5.72 41.45 237.09
DC-10-3 D10 5.72 41.45 237.09
DC-9-10 D91 3.14 17.09 53.66
DC-9-30 D9S 3.14 20.73 65.09
DC-9-40 D94 3.14 22.65 71.12
DC-9-50 D95 3.14 25.98 81.58
E-146-3 BAE 3.38 15.42 52.12
EMB-190 E90 2.74 28.17 77.19 .
OKR 100 F10 3.10 21.19 65.69
RO RJ85 ARJ 3.38 17.81 60.20
B-777-2 777 5.86 49.10 287.73
EMB-145 ERJ 2.10 16.49 34.63
EMB-135 ER3 2.10 12.95 27.20
EMB-140 ER4 2.10 14.70 30.87
MUC79
Mon May 21, 2012 3:06 pm
Hi ferpe, CM, and Flighty! Thanks a lot for your contribution, that already helped a lot!
ferpe
Mon May 21, 2012 9:09 pm
I don't think your cabin areas for the 380 and 747-400 are correct, here my values
380 580m2
744 380m2
Users browsing this forum: Dt91c, rjsampson and 15 guests
