1337Delta764
Attendant Call Panel Light Colors By Manufacturer
Fri Feb 15, 2013 5:38 am
Previously, I did a thread asking why Boeing uses a pink light for the attendant call panel while Airbus uses red to indicate a flight crew to FA call. However, in this thread, I would like to know what are the standard colors used by the different manufacturers.
Based on the information I gathered, here is what I found:
Boeing / McDonnell Douglas:
Pink - Flight crew to FA call OR FA to FA call
Blue - Call to FA from passenger in seat
Amber - Call to FA from passenger in lavatory
Red (717 only) - Lavatory smoke detector set off
Green (DC-9 only) - Unused, included as a placeholder for an unknown function.
Airbus:
Red - Flight crew to FA call OR (some aircraft only) FA to FA call
Flashing Amber - Lavatory smoke detector set off
Green (some aircraft only) - FA to FA call
What about Bombardier and Embraer? Also Lockheed?
[Edited 2013-02-14 21:46:02]
SAAFNAV
RE: Attendant Call Panel Light Colors By Manufacturer
Fri Feb 15, 2013 9:37 am
I'm sorry, I don't mean to be rude, but I think most people here battle to understand your fascination with non-regulated light colors.
Are you doing a project on this or just interested?
Erich
1337Delta764
Fri Feb 15, 2013 3:55 pm
Quoting SAAFNAV (Reply 1):
I am just interested. No problem with that.
cornutt
Sat Feb 16, 2013 4:04 pm
Quoting 1337Delta764 (Thread starter):
I have a vague memory that Douglas intended to offer an intercom system that would allow calls between an FA and the gate desk. Don't know if they ever actually did it or not, but I recall hearing an FA on a Delta flight mention it when I was a kid. Back in the days when a lot of airports didn't have jetways, it would have saved the gate agents a lot of trouble.
1337Delta764
Sat Feb 16, 2013 6:46 pm
Quoting cornutt (Reply 3):
Interesting.
Anyway, does anyone know the colors used by Embraer, Bombardier, and Lockheed?
Viscount724
Mon Feb 18, 2013 2:06 am
Quoting 1337Delta764 (Reply 4):
Wouldn't that be a customer option? For example if a carrier operated aircraft made by several manufacturers wouldn't they want those lights a standard color on their entire fleet so they always mean the same thing? Would be confusing for cabin crews flying multiple types if the meaning of a certain color changed from aircraft to aircraft. Doesn't seem like that would be a very complicated thing to change to meet a customer's requirements.
1337Delta764
Mon Feb 18, 2013 4:49 am
Quoting Viscount724 (Reply 5):
I flew on US Airways this past holiday season, and definitely noticed the differences in colors between the Boeing and Airbus aircraft. The Airbus aircraft (two A321s and an A330) had a red light to indicate a cockpit to FA call, while the Boeing aircraft (a 757, Hawaii version) had a pink light.
bond007
Mon Feb 18, 2013 5:54 am
You found that they are essentially the same, unless you really want to differentiate between pink and red, which mean the same thing anyway!
It doesn't, according to the OP analysis.
Jimbo
David L
Mon Feb 18, 2013 1:21 pm
Quoting bond007 (Reply 7):
That's what's puzzling me. Aren't we just talking about different shades of essentially the same colour? I mean, are the shades of blue the same in all types or are some lighter or darker than the rest? If the effects are achieved by coloured filters over white lights, isn't it just down to the selectiveness of the filter?
1337Delta764
Mon Feb 18, 2013 4:41 pm
The 717 has both pink and red, where pink indicates a cockpit to FA call or an FA to FA call, while red indicates a lavatory smoke detector went off.
bond007
Mon Feb 18, 2013 5:14 pm
Quoting 1337Delta764 (Reply 9):
Like I said, essentially the same. Almost all aircraft use pink/red for the same thing, except one type.
Not sure why the fascination
I was amused by your comment in a previous thread about noticing a "striking difference" between Airbus and Boeing, because one uses pink, and the other red. I guess I don't see much difference at all, also considering they mean the same thing (except for perhaps 1 type).
Jimbo
freeze3192
Mon Feb 18, 2013 8:06 pm
The Bombardier Dash 8 uses solid green for a regular cabin/cockpit call and flashing amber for emergency call.
1337Delta764
Tue Feb 19, 2013 2:24 am
Quoting freeze3192 (Reply 11):
Thanks. What about calls from pax in seat or from lavatory? I presume most likely it would be blue and solid amber, respectively, but I could be wrong. Anyway, it looks like we have found an exception to the pink/red rule (although some Airbus aircraft have green to indicate an FA to FA call in order to differentiate it from a cockpit to FA call).
Scooter01
Tue Feb 19, 2013 9:40 am
Quoting 1337Delta764 (Reply 12):
Just a white pushbutton
http://i46.tinypic.com/308l4t3.jpg
Douglas C-50D (DC-3C) -from 1943
Scooter01
