Quoting divemaster08 (Thread starter):
Now not an expert but I would of thought that in this event, with a generator failing, your already onto your backup before you entered ETOPS airspace so wouldnt that require you to not even enter the ETOPs airspace and return to fix the problem? |
No, for example you can dispatch on an ETOPS flight with a generator inop (although you may be restricted to a shorter time, e.g. 120 minutes)
So losing one is not that serious and you can certainly continue into ETOPS
Remember you have the APU generator as a back up that can power the entire electrical system if necessary.
Losing a second one, however is not good, you are now down to one with your only electrical redundancy on the 767 being the Hydraulic Motor Generator then the battery.
The HMG is really a last ditch back up that only powers select items and the battery even more so, also it only lasts for 30 minutes if you're lucky.
There are a total of three generators on the B767, one on each engine and one on the APU.
