Quoting trnswrld (Reply 5): We're any DC9/MD80 or 727 aircraft ever built without these stairs? |
Quoting MD80 (Reply 6): Quoting trnswrld (Reply 5): We're any DC9/MD80 or 727 aircraft ever built without these stairs? Some early-built DC-9-10s were delivered without the rear stair. |
Quoting Classa64 (Reply 11): I would think removing them completely instead of sealing them would reduce weight, but are they required to work as an emergency exit ? In an evac test when the the plane was certified were the rear stairs working counted as an exit? |
Quoting Dalmd88 (Reply 4): |
Quoting Dalmd88 (Reply 4): The stairs also had to be down while loading and unloading. When down and locked they were a structural tail stand that prevented the nose from lifting off the ground in a tail heavy condition. |
Quoting B777LRF (Reply 17): The door is NOT a tailstand, and only the -100 was handled with the door down.The -200 had a separate tailstand and the door had to be up and locked. We are talking freighters here, as they present the biggest challenge. |
