SXDFC
New 737 LED Landing Lights Question(s)
Sun Nov 15, 2015 7:18 am
Hello All:
Upon reading and looking at the pictures of the UA upgrades thread, I came across the pictures of the new UA LTRTL lights. I also noticed that this replaced the nose gear lights as well. Does anyone know if they replaced the retractable landing lights too? Lastly does anyone have a picture with them lit and if there is any differences to it compared to the older 737 lights?
yeelep
RE: New 737 LED Landing Lights Question(s)
Sun Nov 15, 2015 8:31 am
Yes, the retractable landing lights are also gone.
barney captain
Tue Nov 17, 2015 9:19 pm
I posted this under the First MAX Power on thread for just a bit more info -
A few other changes we've been made aware of that will also be incorporated into future -800 NGs-
A complete redesign of the external lighting system that eliminates the taxi light as well as the fuselage mounted retractable landing lights. You can see those switches are missing in the OPs pic. The new LED LTRTL System (LED Landing, Taxi and Runway Turnoff Lights) is said to provide better lighting as well as save weight and mx costs.
While the taxi light switch remains, it's function has completely changed. With the removal of the nose gear mounted taxi light, activation of the switch now turns on the wing root mounted LED landing lights - but at a reduced power setting. Activation of the landing light switches returns them to full power. Other than being replaced with LEDs, the turn off lights appear to be unchanged.
These seem like good improvements as the lone taxi light frequently provided inadequate illumination. Also it's location subjected it to a lot of vibration leading to early failure. The removal of the retractable landing lights will illiminate the issues of FOD damage from runways contaminated with ice and snow.
Southeast Of Disorder
SXDFC
Tue Nov 17, 2015 11:02 pm
Is this an option or is this going to be standard on all new 737s?
barney captain
Wed Nov 18, 2015 7:55 pm
Quoting SXDFC (Reply 3):
My guess is that this will be the new standard. I know there is a new pedestal coming out as well that will match the MAX.
I wonder if the UA a/c in the pic's has that it.
PGNCS
Wed Nov 18, 2015 11:43 pm
Quoting barney captain (Reply 2):
Interesting stuff. This sounds like a definite improvement as I often found the 737 exterior illumination (and especially the taxi light) feeble compared to other types.
AAR90
Thu Nov 19, 2015 1:03 am
Quoting PGNCS (Reply 5):
AA's newer 738's have the LED taxi light (even had one on an older plane last trip) and it is a very noticeable improvement from the cockpit.
PGNCS
Thu Nov 19, 2015 2:31 am
Quoting AAR90 (Reply 6):
Quoting PGNCS (Reply 5):Interesting stuff. This sounds like a definite improvement as I often found the 737 exterior illumination (and especially the taxi light) feeble compared to other types.
Hey, thanks for the report! As soon as I heard about that I was curious how much better it was than the old dim bulb system. Sounds like a great update.
barney captain
Thu Nov 19, 2015 2:54 am
AA-
Was this the new design (elimination of the taxi light) or a relamp of the existing taxi light to LED?
SXDFC
Thu Nov 19, 2015 4:12 am
So this can be a retrofit too? Is there a component that can fill in the retractable lights too?
Western727
Thu Nov 19, 2015 1:49 pm
Standard on all 737s LN #5555 and up.
Quoting barney captain (Reply 8):
I'm curious about this one too.
Separate question: will the red anticollision strobes get changed to LEDs from LN #5555 and up, too? I think it'd look a bit funny if the LTRTL and white wingtip flashers are all LED while the red fuselage lights stay strobes.
ETA: what about the aft fuselage white flasher? I believe it has remained a strobe while the wingtip flashers got changed to LEDs in the past year or so. Why the "odd one out"?
[Edited 2015-11-19 05:52:36]
Jack @ AUS
Dogbreath
Thu Nov 19, 2015 4:08 pm
Here's a couple of pictures that were taken during the certification testing of the LTRTL in Seattle.
They were taken from a gantry at a height of approximately 50ft to simulate the visual picture on approach.
The existing Halogen Bulb
https://www.airliners.net/uf/78503/1447948265Er3B4f.png
The new LED landing light
https://www.airliners.net/uf/78503/1447948283vKAkov.png
The LED lighting array
https://www.airliners.net/uf/78503/14479491277dsaT7.jpg
Truth, Honour, Loyalty
AAR90
Thu Nov 19, 2015 5:50 pm
Relamp of the Nose Taxi Light. AA pilots have no information on "new design" features that arrive with new aircraft so IF there are any AA 738s with the LED Landing Light Array... I will only know if/when I fly one of those. But I have seen (and flown) plenty of AA 738s with the LED Nose Taxi Light.
yeelep
Thu Nov 19, 2015 6:02 pm
Quoting barney captain (Reply 4):
Our next delivery will have the new pedestal.
andrej
Fri Nov 20, 2015 6:32 am
Quoting Dogbreath (Reply 11):
It's like a whole new World! Pretty nice.
Can the LED landing lighting be retrofitted on other types, such as B744, B767?
Western727
Fri Nov 20, 2015 4:21 pm
Question: why weren't xenon landing lights installed on Boeing or Airbus aircraft prior to the recent widespread use of LEDs? I recall NW/DL's CR9s having those and watching the distinctive "flicker" upon the lights getting turned on, like those in a 2007 car of mine that had xenon headlights.
Jack @ AUS
flyingcello
Re: RE: New 737 LED Landing Lights Question(s)
Sun Nov 27, 2016 10:58 pm
Perhaps the need to provide Xenons with High Voltage? Technically not challenging, but maybe it would have created a certification issue?
NameOmitted
Mon Nov 28, 2016 1:01 am
Lighting designer here. I can't speak directly to industrial LEDs, but in general it is a lot easier to produce blue light than red light with an LED. There is so little red light that naturally comes from an LED you need a much more powerful lamp with much more heat dissipation from the electronics to deliver a meaningful amount of light maybe it through a red filter.
This is speculation, I have no direct experience with aviation maintenance.
parmelbe
Re: New 737 LED Landing Lights Question(s)
Thu Dec 01, 2016 1:09 pm
The difference is remarkable. All of our -700's and older -800's have the old bulbs and our newer -800's are coming in with the LED's. You can tell from the terminal if you have a new -800 incoming from the lights when the jet is on final. Also, pretty sure from what I've seen ours have the nose gear light eliminated. I'd have to check again, though.
ALL views and opinions expressed are mine ONLY and are NOT representative of those of Southwest Airlines
StereoTechque
Thu Dec 01, 2016 3:46 pm
I dont know if anyone else has observed, but the LED's installed in the 787 and the 380 (Guess the Taxi and Runway T/O) have a more yellowish beam rather than pure bright white LED's on the 320 and the 737. Ill always prefer a yellowish white light over the pure white light as it is less irritating to the reciprocal traffic, also it is less prone to glare on objects.
Looking California.. Feeling Minnesota.... R. I.P. Chris Cornell...
ATA L1011
Fri Dec 02, 2016 5:44 am
Will be interesting to see how many operators with low cycle/hours 737 NG/Classics without LED's retrofit as it is available or about to be for both! http://www.talonaerospace.com/products/ ... /wing-tail
Treat others as you expect to be treated!
keesje
Fri Dec 02, 2016 12:03 pm
Seems several options for LED replacements are available / certified now for various aircraft types.
http://www.modstore.aero/modifications/type(71)/Boeing_737%20NextGen/modificationId(28916)/Sealed%20Beam%20Replacement%20Lamps%20-%20LED
tjwgrr
Fri Dec 02, 2016 6:22 pm
I saw an interesting thing today, a DL MD90 (N962DN) with the starboard wingtip landing light, along with the wingtip white flashing light replaced with LED, but the port side wing and nose lights still using incandescent bulbs and strobe. A mix of new and old...... looked rather odd.
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
keesje
Fri Dec 02, 2016 8:02 pm
I think Techops is installing Talon LED on the MD fleet.
Users browsing this forum: DBCooper, GalaxyFlyer, thepinkmachine and 51 guests
