Avsfan
What Can Be Done To Improve This Photo
Fri Jan 05, 2007 3:36 pm
Looking for suggestions on how to hopefully improve this photo.
Big version: Width: 1024 Height: 683 File size: 584kb
FedEx B-727 landing at sunset.
Louis
"Oh I have slipped the surly bonds of Earth...Put out my hand and touched the face of God"
aussie18
RE: What Can Be Done To Improve This Photo
Fri Jan 05, 2007 3:40 pm
Looks nice,maybe abit more USM.....nose looks soft.
D L X
Fri Jan 05, 2007 3:42 pm
I think it's dark, and soft. Brighten up the shot a bit, then hit it with a little USM (200%, .2 radius, 0 threshold.)
Avsfan
Fri Jan 05, 2007 3:52 pm
Quoting D L X (Reply 2):
I shot this in RAW format and left the levels alone since they reached both ends, but did not apply any adjustment to the brightness/contrast. The photo had one pass of USM (300%, 0.2, 0) to a duplicate layer. I will say that the sun was about 5 minutes from going below the horizon.
Avsfan
Mon Jan 08, 2007 9:28 am
Is this version better?
Big version: Width: 1024 Height: 683 File size: 719kb
Nikon D70, Sigma 70-200mm APO f/2.8 EX DG, FL=116mm, 1/500 sec, ISO:200
eadster
Mon Jan 08, 2007 10:08 am
No its still no good. It's too washed out by that prominent yellow colour cast.
I've had a bit of a play with the levels, mainly to see if I could remove some of that yellow.
Big version: Width: 1024 Height: 683 File size: 709kb
FedEx
I'm still not totally happy with the shot, but you get the idea.
Avsfan
Mon Jan 08, 2007 1:12 pm
Quoting Eadster (Reply 5):
Are you talking about on the aircraft or around the aircraft? If you want the original RAW file to mess around with just let me know.
bubbles
Mon Jan 08, 2007 1:59 pm
I think the major problem is the shot looks soft. The following is my edit.
Big version: Width: 1024 Height: 683 File size: 685kb
FedEx B-727
_Hongyin_
aussie18
Mon Jan 08, 2007 2:09 pm
Bubbles edit looks sharp.
eadster
Mon Jan 08, 2007 2:55 pm
Yeah I know the shot is soft, but even if it wasn't, I would doubt it'll get anywhere with the colour cast it has. Thats what I'm trying to say.
fhlaran
Mon Jan 08, 2007 3:14 pm
Not a great result, but I tried to take out this yellow color cast (and I think I wasn't too happy)... Anyway just trying to help since this is a great plane photo  Smile
https://www.airliners.net/uf/536887992/1168236792zhcXG9.jpg
D L X
Mon Jan 08, 2007 3:43 pm
Since it's a sunset photo, there should be *some* orange cast on the plane. The way I determine correct white balance for the shot is using Camera Raw, I put the white balance tool on a spot on the plane that I know to be white/grey that is in the shadow of something. That way, all the light that is falling on it is ambient, and not orange glow from the setting sun.
In this shot, I'd measure off the white part of the fuselage in the shadow of the spoilers.
eadster
Mon Jan 08, 2007 7:43 pm
Quoting D L X (Reply 11):
Agreed, where Fhlaran's version is just a little too extreme!! I think just a little bit of the yellow removed, as I was trying to show will do the trick. Making the aircraft white, also causes that weird effect around other areas.
Sharpen the shot as mentioned, remove some of the yellow, just enough that it looks a little more natural and less washed out and it should be ok.
fhlaran
Tue Jan 09, 2007 12:39 am
Quoting Eadster (Reply 12):
Just a "little" ehehe?? I was reaaaally extreme on my edition lol  Smile
sulman
Tue Jan 09, 2007 12:50 am
Do you have the original .crw file? I'm curious to see it.
James
Avsfan
Sun Jan 21, 2007 9:04 pm
I would like to say "thanks" to those who provided help with or comments on this picture.
Photo © Louis DePaemelaere
Louis
[Edited 2007-01-21 13:12:15]
