I have to say, they all look eminently salvageable. Good shots all round - your editing would benefit from a little more judiciousness.
My personal judgments:
1) has a long blown-out highlight along the fuselage - almost a cert. for rejection unless you're very lucky!
2) is oversharpened (look for those jaggies between wing and flap!) and suffers from a red cast
3) is an excellent image - use the layer method and erase jaggies and sharpening artefacts around areas of fine detail, such as the text 'Belgian Defence' and also around the wheels
4) level it on the runway, and will probably get accepted
5) dark and very oversharpened on the nosewheel particularly
6) oversharpened, possibly dark. like Stefan said, look at those jaggies in the flap edges, erase them!
Overall some very fine shots in that bunch. However if they look the same as those in the queue, it might be a good idea to pull any you have a doubt about and double-check your editing. My advice: find a good workflow and using the layer sharpening method erase any sharpening artefacts carefully first!
Best of luck,
Toni
