Kris
Quoting MarcelSchmidt (Reply 249): I thought a screener could give some feedback as well about this rejection. Mhh..but thanks again Fergul. |
Quoting Psych (Reply 251): On your photo I do see a couple of areas of slight oversharpening, with small jaggies on the underside of the fuselage, at the rear and front (particularly behind the nosewheel and under the tail) and also the rear edge of the horizontal stabiliser. There are slight jaggies on the tail logo where the black meets the white. |
Quoting Varig767 (Reply 257): |
Quoting TupolevTu154 (Reply 258): |
Quoting Fergulmcc (Reply 260): In PS, click on Image-adjustments-hue/saturation, select reds from the drop down menu use your eye droper and click on a part of the image that has the most red and decrease the saturation down a bit, about -6 should do it. Personally I knda like the image the way it is. |
Quoting Psych (Reply 251): have been disappointed not to receive any feedback on my request for clarification about my oversharpening issue on the Monarch photo 15 posts above - so I will try to help out here. |
Quoting TupolevTu154 (Reply 261): I'm going to be totally honest and say that In the two years I have been uploading here I have never used that method before. It solves all my problems! If only I knew of that all this time, my photos wouldn't look so odd! |
Quoting EZEIZA (Reply 259): Rejected for Soft, Level and contrast No biggie there for soft, but I would appreciate explanations on the contrast (the whites are not whites apparently, according to the rejection) and most of all the level rejection. The references for levelling are not there, and the few that possibly could be used are perfectly level. And as I mentioned in the appeal, from this angle all shots will look this way as far as leveling goes. Since I did not get any kind of explanation in the appeal rejection, just the same rejection reasons, I would appreciate any insight. Thanks in advance |
Quoting Fergulmcc (Reply 269): Personally i didn't think there was anything much wrong with the original, if anything, lacking a small bit in color saturation. |
Quoting Plainplane (Reply 271): Quoting Fergulmcc (Reply 265): Well, it didn't. Even more confusing now |
Quoting Plainplane (Reply 263): Here is an unusual rejection from a few months ago. First it was rejected for soft, then I reuploaded it at a later date and it was rejected for sharp and quality. I haven't even touched it. |
Quoting Plainplane (Reply 271): |
