Quoting Vishaljo (Thread starter): just the sheer feel of the Camera, its raw power, the huge viewfinder & the sound of the shutter - i'm hooked cloudnine |
I think this is the much better build quality that any professional level camera has. They don't have the plastic cheap feel of lesser cameras. The D700 is so much more solid feeling - probably the D300 is also the same (although it is 24x16mm format).
The best thing about the FX format Nikon cameras is the high ISO performance. It gives you such a huge advantage in low light. You can get the photo sharp, where your next-door photographer with APS-C type DSLR camera doesn't get the photo, despite their best efforts. Combine a D700 with a fast F/2.8 lens, or even a high quality F/4.0 one with VR - and the possibilities are superb.
Quoting Jwenting (Reply 3): Larger sensors have serious drawbacks.
Lower pixel density for example, more distortion and abberations on the frame edges, higher cost, larger size and weight, higher power consumption, etc. |
I run the D700 on the same
EN-EL3 batteries as I did with the D80 - I haven't noticed any problems with higher power consumption. It works quite perfectly. Yes, the camera is bigger, but it also feels better as well. I have no problem with distortion/abberation.
Quoting Jwenting (Reply 3): At the moment though the larger sensors have roughly the same MP count as their smaller brethren in the same market sector, which leads to lower element density.
That means grainier looking pictures. |
Not in my experience - the 35mm sensors tend to provide much cleaner, higher quality images, and have better performance at high ISO settings - they are less prone to delivering grainy images. At ISO320, the 35mm Nikon D700 has the same clean image quality as the D80 at ISO100. If they are both at the same ISO setting, the D700 is so much better yet again.
Yes, the 35mm ones experience some vignetting near the corners - even on very good lenses, but this is corrected with vignette control on the camera, and what little vignetting is left can be easily corrected with Photoshop.
I wonder, which 35mm DSLR camera did you use that made you come to these conclusions?
[Edited 2009-06-14 19:36:45]
