GRZ-AIR
Pilot Spotting Advice (air To Air, Cockpit Etc...)
Sat Dec 01, 2012 9:59 am
Hi A.netters,
I have a Canon EOS20D with the 28-300 L IS...I just don't seem to be able to get any decent, sharp, air-to-air out of the cockpit shots. The lens is very heavy and combined with often light chops the passing airliner is out of focus, blurred etc...
How do you do it? Would any of you photogs or fellow pilots/spotters share your gear/setup. Maybe I should invest in a lighter setup that is also more travel friendly and easier to hand hold?
Concerning cockpit shots I would be interested in a flash that will not produce a lens shadow even at lets say 10mm...
Your help is as always greatly appreciated!
Thank you,
GA
When I joined A.net it was still free, haha ;).
wilco737
RE: Pilot Spotting Advice (air To Air, Cockpit Etc...)
Sat Dec 01, 2012 10:04 am
Quoting GRZ-AIR (Thread starter):
How do you do it?
Air2air is total luck in my opinion. It needs to be in the right spot so that the cockpit windows don't disturb the picture. I learnt: less focus length is better. I have the 100-400, but in the 744/748 I cannot use it above 120mm or so or the picture gets blurry. Stupid windows.
Cockpit shots are difficult due to the light inside and outside. You need a flash for sure to have the insight brighter. So set the focus on the panel, the exposure for the outside and use the flash. A slave flash is better (not the build in). Then you have a chance to read the instruments on the screens, otherwise they are just black.
I am using a Canon 7D and several Canon lenses and I take soooo many pictures and only a few turn out ok. Air2air is still the worst. I have so many air2air pictures, but none of them are upload worth here.
wilco737
GRZ-AIR
Sat Dec 01, 2012 10:17 am
Servus Wilco,
thanks for the quick reply. The hint with the focal length is great...I'll give that a try next time. Do you use a Canon flash?
GRZ-AIR
wilco737
Sat Dec 01, 2012 10:28 am
Quoting GRZ-AIR (Reply 2):
To be honest, I only have the internal flash of the camera. I don't have an external flash. If you are sitting in the pilot seat the flash sucks, if you are standing in the door, it is quite ok. You need to lengthen the shutter speed a little, to give the camera a chance to make the display visible. Too short shutter speed, the screen is black.
wilco737
n314as
Sun Dec 02, 2012 12:47 am
1. passing planes like those with contrails are not true air to air shots because air to air are only those who are planned in formation flying with a subject plane. BUT they are neat shots. My suggestion is to try to hold it as steady as you can and manually focus the lens to the area that the plane will pass. These are hit and miss shots. Do not use too much ISO because that will kill the quality of the exposure.
2. NEVER use flash in cockpit shots. They will reflect the glass cockpit and ALSO will only catch half of the CRTs information with the other half dark. Professional cockpit shots are timed exposures on a tripod for several seconds at closed apertures with all the instruments lit up. Also they are to be done at night to avoid unsightly things via the cockpit windows. The cockpit windows should be dark.
JAF
No signature
GRZ-AIR
Sun Dec 02, 2012 9:11 am
Thanks for your help.
[Edited 2012-12-02 01:11:27]
jspitfire
Mon Dec 03, 2012 5:04 am
Shooting out the front window, the windshield heat can also distort the photos.
Quoting n314as (Reply 4):
Strong words! Since most of the cockpits I photograph don't have any glass, this isn't a problem and I do use flash.
But I do agree that they look way cooler at night. This one was taken last week. ISO 3200, 0.6 sec, f/5, set up on the tripod.
wilco737
Mon Dec 03, 2012 6:56 am
Never is a very strong word. If you use the flash within the camera, then you are right. But if you put a slave flash properly into the flight deck, then the screens are properly exposed and the outside as well. I don't want either a full white outside or a pitch black outside, I want both.
Sorry for the shamesless plut, but on these pictures I used flash:
Photo © Wilco737
Photo © Wilco737
Photo © Wilco737
But of course there are cases where the screen is black as the flash was directly towards the screens. A flash more sidewards would've been better:
Photo © Wilco737
wilco737
shufflemoomin
Fri Dec 07, 2012 5:41 pm
Quoting Wilco737 (Reply 7):
The blank screens are not caused by the flash, they're caused by a fast shutter speed. If those monitors have a refresh rate of 60hz, that simply means that the flash on and off 60 times per second. Using a shutter speed faster than 1/60 increases your chances of capturing the screen between refreshes and seeing them as 'blank'.
sovietjet
Fri Dec 07, 2012 9:11 pm
If you're in the air and the other aircraft is in the air then it is in fact an air-to-air shot. It doesn't matter if you're in formation. Who the hell even cares? Sorry to burst your elite bubble.
Flash can be used very successfully without getting reflections or dark screens. Is there a rule book that says not to use flash? You offer a technique which is very specific and narrow minded. Not saying it doesn't work, but there are many ways to get good cockpit photos and yours isn't the only way. Nobody cares that it doesn't meet your "professional" standards. Some of the top line cameras out right now have such good high ISO performance you don't even need a tripod anymore. But we shouldn't question you since your are after all the "master photographer"!! Get off your high horse...
Anybody else tired of n314as's arrogant elitist posts that demean everyone else's work?
[Edited 2012-12-07 13:13:14]
ckw
Fri Dec 07, 2012 9:14 pm
Two things to try
1 - bounce the flash off the roof or back of cockpit. This gives a much more even and softer light.
2 - balance the flash with the correct exposure for the external light. Work out the correct exposure for the view outside the window. If it's a crt cockpit, make the shutter speed 1/30th or less. Once you've established that (use the camera meter or a bit of trial and error using the histogram), set that exposure into the camera with it set on manual (this is important). Now take a shot with the flash turned on. The flash will automatically provide the right amount of light to fill in the dark cockpit.
Actually perfectly balanced inside and outside light looks a bit unnatural, so you may want to play with the exposure a bit to get a pleasing look. Note that a decent flash will allow you to vary the output by a couple of stops.
Colin
Colin K. Work, Pixstel
shufflemoomin
Fri Dec 07, 2012 10:54 pm
Quoting sovietjet (Reply 9):
As I said in another post, read his profile. He's under 15 and has been photographing for 4 months. He also lists his occupation as 'master photographer'. He's obviously just an arrogant, obnoxious child. Best to just skip his posts, as I'll be doing.
Users browsing this forum: No registered users and 29 guests
