gonzalu
Screener
Post Screening Advice
Thu Aug 21, 2014 11:10 pm
Hello all,
I am having a hard time finding a middle ground on this image. It was originally rejected for overexposure. On appeal, a head screener said the exposure was fine but that it was blurry and oversharpened.
Looking through the database, I picked a few different images to see if I could find a middle ground that would work but images are (to me) either sharper or softer than mine in different areas. My original was as sharp as other shots I have accepted from the same day and location.
The rejected image
https://www.airliners.net/addphotos/rejections/big/APPEAL_20140821_y1407905007.6981d80_2908_1200.jpg
Others I looked at for reference.
Photo © Tokyo Spotter
Photo © Jjss
Photo © KS - SJST Spotters
Photo © Planecatcher
Photo © Hualiang liao
Photo © Yatrik Sheth
Thanks for your comments
mjgbtv
RE: Post Screening Advice
Fri Aug 22, 2014 12:28 am
Hi,
The bare metal section of the nacelle does appear quite soft to me. It is probably just a trick of the light, but the eye does seem to get drawn to the engine so it is hard to miss. I think I would work on sharpening that up. Nothing else looks soft to me and the only spot that I might call oversharpened is the outline of the rear-most door.
gonzalu
Screener
Fri Aug 22, 2014 12:42 am
Thanks mjgbtv.
Yeah, that diffuser is always very dull and being that it is a rounded edge and not sharp, it usually does not sharpen well.
The rear door being oversharpened, yeah, well, I feel the same way but they always turn out that way at this angle. Take a look at a lot of the images on the db that are angled and the way A.net likes the images sharp, they usually jag a lot because of it being a thin line. On a white plane, even worse... especially if the contrast is high like in very sunny days.
vikkyvik
Fri Aug 22, 2014 3:45 am
Quoting gonzalu (Thread starter):
It does look like it might be a little blurry to me. Slight motion blur perhaps, as it looks like horizontal blur.
zbot69
Sun Aug 24, 2014 12:07 pm
Hey Manny,
That is an absolutely gorgeous image. Flawless. Let me repeat that... FLAWLESS. F-L-A-W-L-E-S-S. Light, composition. Absolutely nothing to add. Your shot is aesthetically as perfect as you can get a shot to be. Perfect light, excellent angle. Gorgeous shot man. GORGEOUS. That's a Photographer's Choice/Photo of the Day image. Awesome capture dude. Keep doing what you're doing and don't change a thing. Put this picture AS IS on flickr or FB, you get 1000+ likes in 2 days.
You've got, what... close to a 1000 images in the data base? And images like THIS getting rejected.
len90
Mon Aug 25, 2014 3:58 am
VERY slight blur at best and I see nothing that makes it over sharpened, in fact I would have thought maybe a little soft given Engine 1s appearance.
Not a fan of this image being held out of the database as it is a beautiful angle.
combatshadow
Mon Aug 25, 2014 5:19 am
For the most part, I think this is a great shot, beautiful image. I'm by no means a screener, but it's hard for me to find any problems with this. If anything, maybe the tail number is just a tad bit oversharpened. But this is much better than a lot of accepted shots.
gonzalu
Screener
Mon Aug 25, 2014 12:28 pm
Thanks for the very kind words Martin, Bob, Len   I am humbled by your comments.
I am going to try another image from the series as I took about 40 shots of the departure. Hopefully another one is less of a challenge to sharpen properly
Cheers!
Users browsing this forum: WZYAFX and 3 guests
