cjmoeser
Post Screening - A Lot Of Things
Mon Apr 06, 2015 4:45 pm
So, I've been in a rut with rejections, about twenty in a row now and can't get a break with any of these photos. I've fixed what they said was wrong and bam four more rejection reasons.
Anyhow, I got this one rejected for Quality, Blurry, Motive and Oversharp. This is also my first attempt at a Portrait photo like this.
https://www.airliners.net/addphotos/r...405_x1427760442.2628n842pa-giv.jpg
This one was rejected for Quality, Oversharp and Blurry. I do not see where it is blurry.
https://www.airliners.net/addphotos/r..._h1427727606.1379giv-n6pc-side.jpg
Thanks for the help
alevik
RE: Post Screening - A Lot Of Things
Mon Apr 06, 2015 10:17 pm
Quoting CJMoeser (Thread starter):
https://www.airliners.net/addphotos/r...v.jpg
I'm at work right now so can;t really judge quality and sharpness, but the portrait crop really doesn't work because the door/airstair is open, and it has been cropped off. If the door were closed it would probably work.
Pete
vikkyvik
Tue Apr 07, 2015 1:53 am
Quoting alevik (Reply 1):
The H-stab cutoff also doesn't work for me, and the slight angle bothers me. Might have looked better balanced from directly in front.
It doesn't look blurry to me, but quality isn't great.
Also doesn't look blurry. Does look soft toward the nose - maybe DOF?
cjmoeser
Tue Apr 07, 2015 3:34 am
Quoting vikkyvik (Reply 2):
Thanks, Yeah I had my aperture at f8.0 so that may have been the issue.
Bogac
Tue Apr 07, 2015 8:37 am
I agree with vikkyvik about the angle for the first image. Its off-balance and that disturbs my "eye".
angad84
Tue Apr 07, 2015 10:39 am
Both shots look soft/blurry and heavily sharpened to compensate. Did you have focusing issues that day? (assuming they're from the same day as the light/background seems similar)
Angad
cjmoeser
Tue Apr 07, 2015 7:33 pm
Quoting angad84 (Reply 5):
I don't believe I had any issues. I was using my Sigma 150-500 and had the OS on 1 and camera on the stationary focus.
No it wan't taken on the same day but around the same time.
vikkyvik
Wed Apr 08, 2015 2:32 am
Quoting CJMoeser (Reply 6):
How far away were you from the aircraft?
cjmoeser
Thu Apr 09, 2015 11:08 pm
I was less than 100ft from the plane.
vikkyvik
Fri Apr 10, 2015 12:39 am
Quoting CJMoeser (Reply 8):
Ah. DOF could certainly be your issue. For a Canon 1.6x crop camera at F8 and a subject at 100 ft, your DOF ranges from infinite at 50mm to 3.65 ft at 500mm.
Nikon 1.5x crop and any full-frame will have lesser DOF for the same field of view.
cjmoeser
Fri Apr 10, 2015 5:11 pm
Ok, I'll keep the dof in mind next time I have the oppertunity to photograph this!
I don't have Nikkon or Cannon. I use Pentax
