jaspc
Pre-Screening - Dark Category, High ISO
Wed Apr 15, 2015 2:59 pm
Hi All,
I know this probably has little chance of getting through but I thought it worthwhile to know what you all think.
This image was made in twilight just before sunrise, hence the dark category. You can see the predawn light reflected on the fuselage. It was actually much darker than this to the eye but the camera compensates for that at high ISO. The image came out of my new Nikon D750, 300mm lens at ISO 6400. I'm also concerned about the tug but I think that might be OK. Clicking on the image will take you to the full 1200 pixel resolution.
Thanks in advance,
JASPC
http://www.josesuroeditorial.com/photos/i-MK2BZTw/0/O/i-MK2BZTw.jpg
Joshu
RE: Pre-Screening - Dark Category, High ISO
Wed Apr 15, 2015 4:23 pm
The tug seems fine. It is a clean image but you are right - It is a little dark.
It doesn't pass the level test for me though.
jaspc
Sun Apr 19, 2015 1:00 am
Quoting Joshu (Reply 1):
Thanks for the feedback. The "Dark category" I was referring to is something that you can "click" on when posting an image if the image was made before or after sunset. That was what I was referring to. I have lightened up a bit though, just in case. The level thing you are right, I need to address that.
Thanks again!
Best,
JASPC
